Sloppy CA
Sloppy CA
Sloppy CA
Bob Achenbach
>Anyone have a good way to apply thin CA to fix hairline cracks? No matter how small I cut the tip of the CA bottle it always seems to dispense way more than intended and runs to areas I don't want it.
Re: Sloppy CA
Re: Sloppy CA
>Bob
I've even tried the micro thin dispensing tubes and it still goes where you don't want. I apply a thin layer of Deft to the piece so the glue won't stain the other areas and then just try not to touch the piece other wise you get your hands stuck to the wood or the tool rest. Not that I've ever done that you understand.
Re: Sloppy CA
Re: Sloppy CA
Wally Dickerman at Green Valley, Az.
>Apply some finishing oil to the area around the crack. Apply the thin glue and watch it run into the crack and just bead up on the oil. The best part is that with this method the glue won't stain the wood surrounding the crack.
Wally
Re: Sloppy CA
Re: Sloppy CA
Bob Achenbach
>Thanks John & Wally
I'll put your suggestions to work right away!!
Bob
