Re: Jet 1442 variable pulley drive
Dennis Taylor (Akron, Ohio)
>I can be of help in this matter...I got a new 1442 lathe, and the lever got very, very hard to move...I contacted Woodcraft and they connected me to Jet direct..Jet had me do the following:
1. pull cover off motor and clean with lacquer thinner...I used brake cleaner...it cleans out the cosmoline from shipping..
2. spray with a silicon lube, all moving parts...
I did these to no avail, they sent me a new one, and it is the same thing..my shop isn't heated all the time, and I think any residue from the cosmoline gets cool and stiffens up,making it hard to change speeds..cleaning will help a lot but not liminate the problem...
I just talked with a Jet rep at a woodworking show, and he made it sound like it isn't possible to happen, but it does and is...trying clean it with the brake cleaner...Jet had me you lacquer thinner, and then denatured alchol, there last recommendation to me was to pull the pulleys off the shaft and then clean, but I didn't feel comforable doing that, maybe you could try it...cleaning will help...any ? email me...Dennis
p.s. I went on with this problem for about 2 months...
