ADVERTISE HERE - FREE TRIAL
First Bowl Post
First Bowl Post
First Bowl Post
Randy in Langley
>I have been lurking in this area of WC for a while now and have learned alot as well as enjoyed seeing all the projects that are posted. I've finally produced something that might be worth sharing.
I decided that I would give some long needed attention to my lathe this past weekend. There have been some issues with my lathe that have been bothering me that I never really got around to addressing. I have a cheap import lathe that I didn't really enjoy using, until I was inspired nearly a year ago to try some new things on it.
Anyhow, the spindle on my lathe was bent, so everything I turned on the lathe wobbled and would wobble doubly if I turned the piece around to finish the bottom. I decided to machine a new spindle for my lathe. I turned it out of 4140 hardened tool steel on my little metal lathe and while installing it on my wood lathe I cleaned and re-greased the bearings as well as installed a variable speed switch, removed the pulley cover door and installed a faceplate on the lengthened outboard end of the spindle. I also spent a portion of the weekend making my own Cole Jaws (Jumbo Jaws) for my lathe out of aluminum plate.
I installed the Cole Jaws on the lathe, mounted a bowl I was working on prior to this lathe venture and finished it off. This is a piece of spalted/figured silver maple from a tree a group of local woodworkers recovered. The wood was dried in the microwave and finished after turning with 3 coats of Danish Oil and buffed with paste wax.
All in all a very good weekend in the shop for me.
Thanks for looking I hope it was worth it.
Re: First Bowl Post
Re: First Bowl Post
Mike Schwing from Md.
>Glad you finally posted. Pretty piece of wood, too! Looks like you took care finishing it. Please post more.
Re: First Bowl Post
Re: First Bowl Post
Mike Rubes, Apex, NC
>Hi Randy,
Nice work! I like that angular shape. It seems to be very well proportioned. Nice job on the cole jaws. I have a set for my Talon and really like them. I use them on just about all turned-rim bowls I do.
Thanks,
Mike
Re: First Bowl Post
Put this one aside
Bob Hackett
>Your first bowl will be an important milestone you`ll want to keep in your collection.
This one will be especially enjoyable in that whenever you look at it you`ll remember both the joy of turning the bowl and the satisfaction you got from doing the turning on the lathe you both repaired and modified yourself.
Mainely,Bob
