Jet Mini Lathe Motor Question
Stan Campbell
>I have the Regular Jet Mini Lathe and I was wondering is there any way to make it Variable Speed?
Thanks
Stan Campbell
Columbus, OH
Re: Jet Mini Lathe Motor Question
Mark Kauder
>Not with that OEM motor.
Mark
Fred in NC
>I converted mine to VS, but it is nothing like the factory VS model. I built a cabinet and mounted the motor inside the cabinet, with a longer belt. It is so much nicer to switch speeds as needed.
I am quoting a posting from another site, I have not verified this info: "Jet 1014 Variable Speed change over kit part number 708351VSR Price: $161.88. Not cheap but will make your old lathe the same as the new. This includes the same motor that is on the new Variable Speed model. "
My conversion cost about that much, but it included all the parts and the wood for the cabinet. The surplus motor I bought is no longer available.
Surplus Center has an affordable controller for DC motors: http://www.surpluscenter.com/item.asp?UID=2004111513194344&item=11-2269&catname=electric
They also carry compatible motors for it.
www.woodturnerscatalog.com has a sale on the VS for $300. Might be worth just selling your lathe, and getting a new one.
Hope this helps.
Motor
Fred in NC
>One more thing: Surplus DC motors in the 1 HP range are plentiful, they are used in threadmills. The controller puts out 90VDC. Unlike AC motors, you don't need to match the voltage exactly, any motor with a rating of 90 V or a little more will run well in 90 V. You will just lose a bit of the HP.
Danny Wells
>Stan,
About 4 years ago, I made a 1HP AC variable speed set up for my Jet Mini. It requires a 220v, 3 phase motor and an inverter. I put mine together for about $300. Now my Jet mini is a "hoss". Having the variable speed is great, and with the inverter there is no loss of horsepower, and you get reverse as well. I wrote an article on how to do it. If you like I'll e-mail it to you.
Danny
Re: Jet Mini Lathe Motor Question *LINK*
Wes Bischel
>Stan,
I have seen a few others put the motor and controller from these guys in their minis:
vegawoodworking.com
They seemed to be happy - though I have not used this set-up myself so YMMV.
Good luck,
Wes
Vega WW
The Vega option is no longer available. *LINK*
Don Henthorn Smithville, Texas
>Wish it were because it was a good low cost method of making the Jet 1014 better than the new variable speed Jet min.
http://users2.ev1.net/~henthorn
Unfortunately true...
Fred in NC
>The motors were surplus to Vega, and they ran out. I am using one, and it goes down to about 60RPM. Great motor and controller! They are DC motors.
Second best motor and controller can be bought from www.surpluscenter.com for about $90 for both. Motors are 1-1/2 HP and up, normally used in treadmills. A used treadmill from a thrift shop could be a source for motor and controller.
By the way, the DC motors don't lose torque at low speeds because the controller does not vary the voltage. It is PWM based.
Stan Campbell
>PLEASE.
I really, really want Variable speed.
Thanks
Stan
Columbus,OH
Stan Campbell
>Thanks Fred
I wrote to Jet to see what they had to say.
Thanks
Stan
Columbus,OH
Re: The Vega option is no longer available.
Wes Bischel
>Oops, sorry about that. I even went to their website to make sure - I guess they haven't updated the link.
Wes
Re: Article is in cyberspace on its way
Danny Wells
>Stan, I just you the article with some pics direct via e-mail.
Danny
John Weeks
>The problem with the factory conversion, assuming it's the same motor they supply on the mini-lathe from the factory, is that the minimum speed if the VS motor is still 500 rpm. This was pointed out to me at a store opening where they had Jet Mini's with both the regular and the variable speed motors.
I don't like the 500 RPM minimum either
Fred in NC
>That is the reason why I went through the trouble of installing my own conversion. Besides having a very low speed (60 RPM), I don't lose any torque at the lower speeds. And the motor develops well over a horsepower.
My total cost was about $160, if I remember correctly, but that included materials for the cabinet.
