is there a 1/2" to 3/4" metal adapter out there???
-e-
>want to use 1/2" hollowing tools with my JAMIESON STABILIZER HANDLE which accepts 3/4" ... anyone know of an available metal adapter.
i made my own wooden ones but they don't wear well.
Re: is there a 1/2" to 3/4" metal adapter out there???
Robert Savit
>McNaughton sells a set of adaptors for use with their handles. Works well in anything that accepts 3/4".
Bob Savit
Lyn J. Mangiameli
>Don Pencil makes some that are designed to be used with his Scorpion System., but should work OK in your application. Available from his web site
Kelton Makes some to be used in their Ulimate Handle, which should work well, but might need to be shortened slightly. Available from Craft Supplies
Hamlet includes one with their Goliath Handle, but it may be impossible to obtain it individually.
Keith Clark (OKSpinDoctor web site) will likely make one up for you. He recently made a special 12 mm adapter for me for use with his Hollowing System, but it could be easily modified for use with the Jamieson.
Jorge Castaneda
>e,
Any machine shop can make you one in minutes.
Ask the nearest to you.
thanks for the info
-e-
>thanks robert, lyn and jorge ... i'm checking your suggestions out.
John Jordan
>I can send you one for a couple of bucks. Tell me how long to make it. You will need to drill your own hole for the setscrew.
John Jordan
Make him sign it :-)
Lyn J. Mangiameli
-e-
>tanks ... i've emailed u
