spindle shaper
spindle shaper
spindle shaper
george hoffman
>Hello wood turners:
Are there any pros or cons out there regarding to adding a router collet spindle to my Delta Rockwell shaper. Shaper spindle is 1/2".
Thanks,
old woodturner George
Re: spindle shaper
Only one con...
John Cotten
>Shapers typically turn in the 7,000 to 10,000 RPM range, while most routers turn from 18,000 to 24,000 RPM. Adding the router spindle to the shaper is not a bad move, but you will have to pay particular attention to the feed rate to get a clean cut.
