Need more help...improving tools...
BubbaBob
>Boy I love this place.
I asked, just Monday, about making hollowing tools, and due to the great advice, I made some yesterday and used them to turn a couple hollow vessels. You can't beat help that makes that happen. Thanks, guys.
Now I have another question...
The four tools I made work great from my perspective...after all, I've never done hollow turning so anything that allowed me to do it was good, but...
I cannot help but believe the tools can be improved, specifically the cutter tip orientation. I made four tools, 1/2 and 3/4 straight tools, and 1/2 and 3/4 swans neck tools. What would be the optimum cutter orientation for these tools? Any other tidbits anyone can share? I bought enough steel today for 5 more 1/2 inch tools and 5 more 3/4 inch tools. Any need for 1 inch tools? Any advantage to using square stock rather than round as I have now? Anything else I should know?
BubbaBob
Re: Need more help...improving tools...
Wally Dickerman at Green Valley, Az.
>One of the advantages in using a Stewart tool, or one those that copies his, is that they have a cutter that can be swiveled. Thus, depending on where you are inside the vessel, the cutter can be presented to the wood to get the best cutting action. I like a round bar because the tool can be tipped down a little to get sort of a shearing cut. This is especially true when using a round scraper on the tool. I have an old boring bar made by Jerry Glaser that has a swiveling cutter.
When cutting inside a vessel, always cut on or a little above center. Helps to avoid catches.
Wally
Thanks Wally...much appreciated.
BubbaBob
Mike Schwing from Md.
>Wally, I understand the cutting on or above center, but is it particularly advantageous to have the cutter angled up or down? I tend to do my hollowing with the tool tip lower than the other end of the bar, so I doubt I'm ever cutting above center, maybe even a little below I guess, but I don't recall ever having a catch when hollowing a piece. Now you have me wondering if people hollow with their bar level, angled up or down.
The key thing to remember is...
Bob Hackett
>If the cutter catches will it be driven deeper into the wood or out of the wood.
A scraping tool used for hollowing should be cutting above the centerline of the spinning piece.
The bar or tool should be set up so the cutting edge is presented to the wood at an angle below the horizontal line drawn thru the center of the bar or shaft.This makes the cutter function in a trailing mode just like a conventional hand held scraper.
There`s two different centerlines to consider in the set up process.
I hope this make sense,I`ve read it twice and I think it does but one never knows.
Mainely,Bob
>I feel that all cutting or scraping inside a bowl or vessel should be done on or above centerline of the piece. I also like to have the cutter on my stewart tool angling slightly down. Since the cutter itself is just about aligned with the top of the bar, the tool rest is set so the my tool angles down a little, and with the tool tipped down the cutter is sowewhere around center. In the hands of a skilled turner, it it strays a little below center it doesn't really matter. However, when I'm teaching classes to less skilled turners, I watch that pretty close. The occasional catch by the students bears that out.
Wally
Duane C.Leach
>Hi Mike
If you are cutting or scraping inside a hollow vessel and your method is giving you good or great results with noooo catches then why even think you might be doing it wrong. If it ain't broke don't fix it.
Happy turning
Duane
Richard Allen
Richard Allen
>Hi BubbaBob
If a round bar acidently contacts the opening of the hollow form while turning the damage to the spinning wood is slight.
If a square bar acidently contacts the opeing of a hollow form while turning the potential for dammage is much greater.
Thanks
Richard
Excellent point ! -
Fred in NC
Jim McTavish
>Hi BubbaBob,
Our woodturning club here in the Fargo ND area has an annual toolmaking day every February. Using the 3/16" square cobalt cutters from Enco, we made tools out of 3/4" cold rolled round steel. The round stock was formed using a hydraulic bender. Here's a photo so you can get an idea on the shapes.
Jim McTavish
Thanks to all
Ken DeMarco
>Bubbabob, and all who responded<
Thanks, theese have been some absouloutly great threads for beginers like me on how to make holllowing tools, is there anyway we can get this saved as an article?
Thanks
Ken DeMarco
Sylvania, OH
Thanks to all YES ! -
Fred in NC
>This has been a very informative thread. Thanks everyone. I have been looking at hollowing tools at the store, and frankly did not find a reason to buy them. I have done a little metal work, so I think I can tackle it. My immediate need is for some small tools, so that will help me get started. They are easier to bend!
The idea of a club toolmaking session is great, thanks Jim McTavish. I will suggest it to the chapter I belong to in Charotte, NC. Maybe we can do it early next year. Sharing a hydraulic bender will help everyone.
Hey Bubba, do you have enough room for all your new tools ?
Only six so far...
BubbaBob
>...but that will change...LOL.
One problem...if I screw up a turning, I have fancy firewood. A messed up attempt at making a tool doesn't produce burnable scrap, so what do I have then? Weird shaped paperweight?
BubbaBob
Re: Only six so far...
Fred in NC
>Ah! A new FANGLED tool ... and you might be able to patent it!
Re: Better Yet . . . .
>List it on E-Bay (be prepared to make about 500 of them) and make enough $$ so you can buy "pro" tools.
Good idea...
Fred in NC
>What are we going to call them ?
This is baaaad...
BubbaBob
>...BubbaBob's Wood Scooper Blooper?
BubbaBob
