Have a question? Ask Woody!
Cherry and Maple bowls
Dominic Greco in Richboro PA
>Hi Everyone,
Below are pictures of (2) bowls I completed this past weekend. The first is a spalted maple bowl whose wood was so punky, I had to treat it once with sanding sealer, then wet sand with a 50% varnish / 50% mineral spirits mix. The second is a cherry bowl that also got the same wet sanding treatment.
These two bowls were a bit of an experiment for me in form. If you notice, the profile on the maple bowl and the profile of the cherry one are inverted in respect to one another. The maple bowl is fatter at the base, where the cherry bowl is larger near the rim. I just wanted to see what happened when I tried that out. What do you think?
Spalted Maple Bowl Specs:
Outer dia.: 6 3/4"
Height: 4"
Wall thickness: 3/16"
Rim dia.: 5 3/8"
Base dia.: 4 1/4"
Sanding Method: Wet sanded to 2500 Grit.
Finish: Watco's Danish Oil
Final: Buffed with Beall System
Cherry Bowl Specs:
Outer dia.: 6 3/4"
Height: 5"
Rim dia.: 5 1/2"
Base dia.: 2 3/4"
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Cherry and Maple bowls
2nd Pic
Jennifer@Indy.USA
>Nice ones Dom,
I've seen this shape before and although at first I wasn't sure about it.....I have grown fond of it. I call this form the Brandy Snifter shape : )
These are really nice!
Jen
Re: 2nd Pic
Glenn Hodges
>Beautiful! They will grow even more beautiful with age.
