Veritas - Innovation in Tools
End grain hollowing tools?
Bob Hackett
>First let me say that I haven`t done much endgrain hollowing lately.Why I would suddenly agree to make a batch of large,deep endgrain pieces after I have loaned out or given away most of my appropriate tools is beyond me.Next time I`ll look at the tools before saying yes.
My question is;with the new advances in endgrain hollowing tools what tools do those who do alot of this favor?
Most of my old tools either clogged with chips(Technatool),were difficult to sharpen(Termite and other ring/hook tools)or were too short or thin for much overhang off the toolrest(spindle gouges and scrapers)or too slow(scraper type boring bar).
I need to quickly hollow out to 6"+ ID to a depth of 8"+ and the wood is fresh cut maple and red oak.The bottoms are flat as are the sides(think wood canisters).
I need to quickly hollow about 30 of these.I agreed to make afew to display/store other items and now everybody wants them(including a large one "made from a stump if possible").As they say,no good deed goes unpunished.
The good news is SWMBO has agreed to a new tool if I make some for her too.So please HELP!!
Mainely,Bob
PS-A large Foster bit just slips the belt on my Conover(2 HP DC drive) in wet wood,the steam produced is impressive though.
Re: End grain hollowing tools?
Ken Grunke
>Bob, I have a hook tool I ground from a 5/16" HSS square bit, set in the end of a 3/4" dia. bar, about 32" long that would work good for this.
When I use it with a Jamieson rear restraining rest, it really hogs out the wood.
Here's a pic of the business end:
Doug Leite
>Bob,
I like the Soren Berger "Viking tool". You need to drill a hole to depth first then do your cutting from the hole out. I often cut as much as 1/4"-3/8" depth at one time. If I was doing your project, I would use it in a square tubing bar on a square tool rest with pivot pins and the rear on another tool rest constructed of 2 parallel bars to restrain the sq. boring bar from twisting. It takes all of the strain off of the arms and makes that an easy job. Works for me.
Aloha,
Doug
Thanks guys
Bob Hackett
>I think I`ll try the Berger tool as it`s one I was looking at.How hard is it to sharpen?
In the meantime I`ve printed the pic of the hook tool and may make one if I have the correct piece of HSS in the shop.Do you use yours on a boring bar system or just a conventional handle?I`ve got a small diamond cone I`ve been using so I`ll size it so I can use that to sharpen it.
Thanks again.
Mainely,Bob
PS
Bob Hackett
>I reread your post Ken and if you`ve got it in a 3/4" bar then I guess it must be in a boring bar setup,can`t imagine what the handle would look like if you didn`t.
I also see a captive boring system being thrown together in my future.
Do you use a conventional forward rest or a pivoting shoe to hold the bar close to the work?
Mainely,Bob
Re: Thanks guys
Doug Leite
>I have no trouble sharpening it, but I did do a one day hands on with Soren 6-8 years ago. He now sells a sharpening aid, I've seen it in the Craft Suppies catalog. I don't use and jig, just lightly grind the flat edge and rotate up onto the "gouge" edge. You could probable use a diamond file successfully. It cuts a lot of wood between sharpenings.
Aloha,
Doug
Re: PS
Ken Grunke
>Bob, I use a conventional toolrest near the work.
I was gonna suggest the Berger tool also, it would be easier to grind than my hook tool if you wanted to make your own. I think it would be more appropriate for cutting a flat bottom on end grain but the hook tool would hog out the waste quicker.
BTW, my handle is just a straight 3/4" round bar with the end drilled to 3/8", and a setscrew. I was going to put some kind of anti-torque handle on it, but didn't find it to be necessary--the tubular foam grips do a good job without it.
Jorge Castaneda
>Bob,
I have a limited experience, and must of what I've done is with a square and round scrapers and sometimes a gouge for the initial hollow, the square is a 1/2" and has a slight skew, the left being the long point.Of late I had a similar request and I have been experimenting with the old but excellent forstner bits from Convalco, in the big sizes they have 1/2"shanks, of more than 6", the only one I managed to use succesfully has been the 3/4" because my midi cannot be slowed further, if you can turn at very slow speeds, you can make a 1 1/2" or even a 2" hole in a short time. Also, woodcraft offers a whooper of a square scraper, 1/2" thick by 1" wide and the blade is slightly longer than 7", the handle is rather short, but you can make a longer one yourself, to use this monster, place the tool rest slightly above center. I got my Convalco's from Jamestown distributors, a while back, they must still carry them.
Hope this helps
Jorge
Fostner bits
Bob Hackett
>Thanks Jorge,
I`ve been trying to drill with some old 4" sawtooth bits I had hanging around.Even after sharpening them it was too much.I`ll take a look at these others.
I had been using a long scraper like you suggested.It`s made from 1/2" thick HSS and is 21" long(the shear scraper I showed you made from a hogging knife).I think you saw the rounded end,I am using the other end.It`s working but tough on my arm.What I was really looking for was a tool to hog the waste wood from the inside before I picked up the scraper.I think I`ll center drill and then go with the Soren Berger tool as it looks like the easiest to sharpen(that hook tool has peaked my interest though).
Thanks.
Mainely,Bob
Re: Fostner bits
Jorge Castaneda
>Bob'
That is what I thought too, saving that arm, you are right, center drill and then go with the Soren Berger tool will make the job easier, if you cannot find a forstner bit, I almost positive I have two 1 1/2", and will be glad to let you have one, let me know.
Jorge
Convalco
Jorge Castaneda
>Bob,
I just did a search and the Convalco site came right uo, here is one of the pages with forstner bits:
http://www.router-bits-shaper-cutters.com/products/index.cfm?Product_Group_ID=2&Product_Category_ID=36&Start=21
Thanks
Bob Hackett
>I need all the help I can get.;^)
MB
