lathe to buy
lathe to buy
lathe to buy
Dave B
>I would like to buy a lathe, but would like to avoid having to buy more than one. If I bought a jet or delta midi lathe would I be able to do something as small as pens and as large as table legs for a dining room table? Say for example a leg that starts out 6x6x35.
Re: lathe to buy
Check out these 2 threads
Mike Schwing from Md.
>Survey - how many own only one lathe?
http://www.woodcentral.com/cgi-bin/turning.pl?frames;read=42525
How many own more than one lathe?
http://www.woodcentral.com/cgi-bin/turning.pl?frames;read=42391
The responses to the latter are overwhelming. I have only one lathe but lately really wish I had a smaller one for collars, or even a 2nd big one for a dedicated hollowing setup.
Not too many table legs exceed 30", but be careful with whatever you buy because sometimes the advertised bed length doesn't take into account the tailstock requirements.
In the reviews section I have a write up on my first lathe - a Delta 1440. Please check it out before buying a lathe, it might help you realize some important things to keep in mind when purchasing a lathe.
Re: lathe to buy
Re: lathe to buy
Fred in NC
>One point comes to mind: bed extensions.
A bed extension does not make a lathe more powerful. A 6" diameter x 35" table leg would be too much both for the motor and the mechanical strength of the bed.
Re: lathe to buy
Richard Allen
Re: lathe to buy
Richard Allen
>Hi Dave
The mini lathe has a 10" swing over the bed but closer to a 6" swing over the banjo (the thing that holds the tool rest). A 6x6 has a large diameter of more than 8". You would not be able to turn a 6x6 between centers on a mini lathe.
1/2 HP would be enough power to turn a table leg but you would have to take light cuts. The bed extensions work fine and the mini lathes you mention would easily be strong enough to turn the table leg you describe.
If you knock the corners off the 6x6 you might be able to get it over the banjo.
Chance are that you will become infected with the turning bug, as so many of us have, and the capacity you desire now are going to seam meager in a year (actually 3 months but we like to tell new people that their investment will satisfy longer than 3 months).
Good Luck
Richard
Re: lathe to buy
Re: lathe to buy
Shawn - in ID
>Speaking as one in the "I have a mini but want a big boy lathe" boat, my advice is to buy big if you have the cash to do so. You'll get tons more advice if you re-post with an idea of how much you're willing to spend. My advice is to go with a "full-size" lathe if you have the dough and space. Otherwise, a mini/midi with bed extension should just satisfy your posted requirements.
