How do I burnish the face of a plate?
Ron in Drums PA
Ron in Drums PA
Clarification
Ron in Drums PA
>I know on side of a bowl I use a thin parting tool to make a groove, then use some wire to burn while the lathe is spinning. I can't figure out how to do this on the face of a plate.
Any suggestions? TIA
Re: Clarification
John
>Make your groove as normal, then use a stick of ebony, sharpened like a pencil, or beveled like a chisel, and run the point in the groove and add pressure - the friction will burn it in. If your plate is a light wood, like maple, try a different color exotic wood, and burnish it in with that - say, paduak for a red line.......
Re: How do I burnish the face of a plate?
Mac
>Try cutting a piece of tempered masonite to the shape of a handle with a point on it.You can sharpen the point to the thickness you need.Holding this in the groove with a bit of pressure will make a burned groove.....
Don Evans
>Use a soldering iron, pencil style-type.
Heat the end of a metal rod, that you have ground round, with propane torch.
The first pyrograph work was done by burning small sticks and using immediately after blowing out the flame.
There are lots of ways.
Andrew Hilton
>I used to use the wire trick for burning lines in my turnings. But, I had the same problem as you so I took a different approach and do it this way regardless of whether it's a spindle turning, bowls, hollowforms, etc. It works equally as well regardless of the form....
Simply take a fairly sharpened stick (the working end is narrowed down as to not interfere with other wood surfaces in the turning) and drive a small nail or insert the appropriately sized wire into the end of it. Bend over that nail/wire over on itself and insert that end into the end of the stick as well. Leave just enough of the nail/wire sticking out (it'll be the bent over portion) so it'll make contact with the wood instead of the wood of your tool making contact with the wood.
Put your new tool on the toolrest and push it into the wood. You'll get a burning with enough lathe speed and pressure against the wood. Make a slight groove in your turning to accentuate that groove before applying the tool to burn it.
No messing with all sizes of wires hanging around the shop. No safety concerns with the wire getting caught in the wood and flying around at you. No worrying about trying to get wire at the correct point on a steep angle. No wire burning through itself and snapping.
It's not a perfect solution but it's far more flexible and safer than a wire.
Dick Hines
>Go to Lowe's or HD and pick up some of the counter top sample chips. They are free. Just hold then the what ever you want the line burned on and go to it. A added advantage is unlike wire you never have to worry where to put the "hot" wire when you are through.
Steve Mushinski
>Use sand paper. David Nittmann uses this method of the edge of sand paper pushed into the grove. I think it was like 150grit. He said he has tried hundreds of different ways and the sandpaper works the best.
