Veritas - Innovation in Tools
Jet 1236
Jet 1236
Jet 1236
Howard Norman
>After owning a Jet 1236 for sometime I am now starting to use it. I am finding that the variable speed control is not working smoothly. Is there routine maintance that can/should be done with this control?
Howard
Re: Jet 1236
Clean it!
Dominic Greco in Richboro PA
There must be a rash of these problems going around. This is the third I've heard in the last month! I had a similar problem with my Jet JWL-1236 and it turned out to be accumulated dried up Cosmoline interfering with the internals.
Basically, you need to clean the cosmoline off of the Reeves Drive (mechanical variable speed mechanism). I use mineral spirits and a rag to do this. Wipe off the pulleys, try to move them a bit, wipe some more, etc, etc. You get the idea.
After you're done, be sure to lube with something other than Oil, WD-40, or grease. All of these things will ATTRACT and hold sawdust. I use a dry film silicone lubricant from Dow. I believe it's #557. McMaster Carr carries it. I lube all the internal mechanisms of all my woodworking tools with this stuff. Since it's essentially a dry powder, it does not hold sawdust. And it seems to last a lot longer than oil.
See ya around,
Dominic
Re: Jet 1236
Ditto
Ron in Drums PA
>I didn't feel like taking the reeves drive apart. I have a spray can of brake parts cleaner that did the job. Then I sprayed with some silicone.
Re: Jet 1236
Re: Clean it!
Howard Norman
>Thanks Dom, don't know why I didn't think to clean the Reeves drive. Old age setting in I guess.
Howard
Re: Jet 1236
Re: Ditto
Peter Teubel
>Ditto. That the same proceedure I use.
Re: Jet 1236
Re: ? Ditto
Lea Lysett
>Hi
So you just spray the brake cleaner and clean it as well as you can. Then spray it with silicone spray to lube it?
I havent opened mine up yet and it does stick just a bit before it is warmed up. Jet 1442 owner.
Re: Jet 1236
Yep, clean it... then use it
Chuck Ludwigsen
>I had trouble with mine as well at first. Cleaned it good, lubed it better, used it often ever since.
What I mean is if you move it through the range of speeds each time you use it, it seems to "break in" and not hang as much. Also, try to take it back down to "slow" before shutting down for the night. It will keep less tension on the belt.
Chuck
Re: Jet 1236
Re: ? Ditto
Ron in Drums PA
>After a while that has happened. I use the spray cleaner and lube again.
Re: Jet 1236
Re: ? Ditto
Peter Teubel
>Personally, I take the belt cover off, turn on the lathe, and spray the brake cleaner along the shaft while moving the speed control back and forth. Wear eye protection! After its cleaned up, I turn off the lathe and spray the silicone lube on the shaft, turn it on, move the speed control, stop the lathe, spray the lube, etc. I have to do this maintenance every 2 months or so to keep the speed control working smoothly.
