mini outboard?
mini outboard?
mini outboard?
Shawn - in ID
>Anyone every rig a mini lathe to turn outboard? Could have an adaptor made to thread on in place of the handwheel with 1"8tpi outer threads(?).
Re: mini outboard?
Re: mini outboard?
Andrew Hilton
>Haven't made an outboard faceplate but I've done a fair share of modifying and replacing the stock handwheel of the Jet Mini though. If I remember right, it's a 3/4" x 12 tpi spindle on that side.
Besides the safety concerns in doing something with a machine that it wasn't intended for (bearing loads, weight, etc.), here's a reason that turning outboard isn't going to work too well...
There's a wave washer between the handwheel and the bearing holding the spindle. Tighten the handwheel too tight (same effect when putting chisel to wood while turning outboard) and you'll bind things up on that bearing and things won't spin at all.
Re: mini outboard?
Re: mini outboard?
Shawn - in ID
>Thanks Andrew. I have a VL100 and the seating of the handwheel against the bearing must be a bit different than the Jet because it doesn't matter how tight the handwheel is - everything spins just fine. I appreciate your comments on reaching outside what the tool was designed for; maybe the spindle and bearings aren't sufficient to handle 16-17", which is what I'm looking for.
Re: mini outboard?
Even if you figger out how...
BubbaBob
>...to do it,turning 16-17 in diameter on a mini/midi sounds like a recipe for disaster to me. I'm the type to try anything once and even I won't go much above that size on my Jet 1442 with 500 lbs of sand as ballast...
BubbaBob
