What is the name of this turning tool?
Phil Winn
>1. What would this turning tool be called.....
A tool which is "like" a skew BUT has the
shape of a regular "chisel"? (Is a regular chisel but has an edge like a skew?)
2. If I can use a regular "flat bottom" skew,
is there any reason for me to purchase a
"curve bottomed" skew?
Thank you so much!
Phil
Re: What is the name of this turning tool?
Re: What is the name of this turning tool? *LINK*
RevDoug
>Phil,
Is there any chance we could see a picture of this tool?
Turn 'em round,
RevDoug
Wood Spun Round
RevDoug Re: What is the name of this turning tool?
Phil Winn
>RevDoug,
I don't know how to post a picture--but how about this...
If you were to picture the capital letter "T",
where the "upright" of the letter was the shaft
of the tool and the "top" of the letter was the cutting edge...does this help?
Thanks,
Phil
Square nose scraper ?
Fred in NC
Fred Re: Square nose scraper ?
Phil Winn
>Fred,
Does a scraper have a beveled cutting edge like a
skew?
Thanks,
Phil
Fog Tanner
>Sounds like a beading and parting tool. A aquare ended chilsel, that is beveled like a skew.
Not quite sure what you mean by a round bottomed skew. Are you talking about a round skew, one with rounded edges or a spindle master. I use both the flat, rounded edges, and round skews. I don't really have a preference either way for the rounded edges, I learned on a "flat" skew. And I don't really care for the spindle master. But if you really want to mess your mind up, get a triple point. But, only after you learn how to use a 'flat' skew.
Fog Tanner
>I had forgot about the oval skews. That may be what you are talking about as a "round bottom". I never found they were of any advantage in rolling beads. That is what they were marketed for. For me they are a little flimsy and no better at rolling beads than a square or rounded edge skew. If you are using a regular flat skew or one with rounded edges, I would stay with it. But, that is just my preference. Others swear by the oval or rounded bottom skews - its like Ford and Chevy, depends on what you drive as which is best.
Bedan?
TDaniel
>Phil
It sounds like you've seen a skew that is ground flat across the cutting edge or 90 degrees to the shaft rather than the usual 45 to 60 degrees.
There isn't any reason you can't use a regular carpenters chisel except that the handle is too short. Most carpenters chisels are sharpened between 25 and 35 degrees which makes them kind of grabby when used as a skew. I usually demonstrate with a carpenters chisel when teaching the skew to show that all cutting edges are the same. I also demonstrate turning with a side ax, and a drawknife.
I think you'll find a woodturners skew to much more usable and user friendly. The longer handle gives you more control because you can use your body.
I've seen what some people call a "round skew". It's round on the bottom and flat on top. I built one to see how they work and it's really just a spindle gouge without the flute. It cuts slower and not as cleanly because the cutting edge is a less sharp angle. they are easy to make however so if you need a tool like that just find some high quality steel such as Drill rod and gring what you want. harden it and sharpen it and you've got a tool.
Fred in NC
>It usually has a bevel like a woodworking chisel, but the angle is not so steep. Most square scrapers have a single bevel, but sometimes they have two, with a short bevel on top.
I suggest you look at woodturning catalogs or woodturning sites in the web. They have pics and descriptions of these tools.
Sounds like it
Jorge Castaneda
>Phil,
Without looking at it it is just a guessing, as TD suggests, it may be a bedan, it is used to make cilinders, as in small tennons, but it can rool beads too.
About the aquare or round bottomed skews, the rounded bottom is more forgiving and it helps when you are rolling the skew, gives smoother cuts and if there is a catch, it does not dig into your tool rest.
Hope this helps
Jorge
Keith Tompkins
Keith Tompkins
>Hi Phil, the tool you are referring to is a woodturning chisel. This is the type of tool used by Peter Child, and described in great detail in his book.
He felt this was a superior tool in many ways to the conventional skew chisel. I use one also, I agree with much of his observations.
Keith Re: What is the name of this turning tool?
Phil Winn
>I am using a regular wood chisel and it works
"better" for me than a regular skew---I was hoping to get a proper tool to use---Thanks
a million---now who makes one of these
woodturning chisels? Which widths do they make them in? 3/4", 1" 1 1/4"? Where to purchase?
Thanks,
Phil
Keith Tompkins
Re: Keith Re: What is the name of this turning too
Keith Tompkins
>Hi Phil, you will probably have to grind your own, as I did. Piece of cake! (an old scraper would be ideal)
Joe Herrmann
>Can someone post a photo of this tool??
Joe
Bedan *LINK*
Pascal Oudet
>Phil, have a look at the page below where several views of a bedan are shown (as well as uses for it). it is the tool you are describing ?
Pascal
Bedan's page
Re: Keith Re: What is the name of this turning too *LINK*
Hans Scholte
>Square end chisels are made by Henry Taylor. In HSS they have sizes 1/2" to 1 1/4".
http://www.henrytaylortools.co.uk/chisels.html
