drive center stuck, help!
Mike in Mystic
>Hi everyone,
I was testing out the new stand I made for my Jet min-lathe and I took a cut-off and stuck it onto the lathe. I used a brand-new 2-prong drive center. Well I played around for a bit and when I tried to get the drive center out I found it to be unbelieveably stuck. I took the tommy bar (or whatever it is called) through the headstock and was putting what I'd call a helluva lot of force into wacking on it and it hasn't budged at all.
I am at a loss as to what to do. I'm sure this can't be the first newbie to get himself into a spot like this, so hopefully you experts can point out my ignorance and help me get this thing out.
Thanks!
Mike
Re: drive center stuck, help!
Fog Tanner
>You might do a search in this group. There was a similar thread in the last sevral weeks, with a number of replies. An don't feel lonesome, all of us have done it. You learn real quick to wipe off the drive spur and clean out the morse taper. If you get particles in the MT, you will get a bind, if you twist on the spur, you can gall the MT and/or spur depending on the material. One guy in our club had the same problem and ppunded on the spur for a couple of hours. Another club member came over and told him to pour vinegar down the shaft, he did and the drive fell out - might be work a try..
Wood Spinner
>If all else fails pack the drive spur in dry ice to shrink it down. The knock out bar I use is a trailer ball head welded to a rod. It works great due to the added umph of the ball weight.
Be patient and don't damage your machine.
Good turning and be safe
Bill
bill Crommett in seneca
>I have one spur center that persists on getting stuck. I could find no defects, so I retired it to the junk box.
Walt
>Hi Mike,
I had the same thing happen to a brand new Jet mini-lathe. I was able to wack it out, but in the process I think the head got a little loose along its axis. Watch how hard you hit it.
Walt
Damage to bearings
Fred in NC
>In reading these posts, I wonder if it might not be better to remove the spindle from the headstock before pounding too hard on the knockout bar. This might avoid damage to the bearings, and possibly cracking the headstock, throwing it out of alignment, etc.
Wood Spinner
>How about using a bearing puller. Grip the hand wheel and use a metal rod inside the headstock.
Bill
