Small Basket Photo Article *LINK*
Andrew Hilton
>Jennifer,
Here you go.... If this doesn't explain it well enough, just let me know.
Small Baskets Article
Andrew Hilton
>Jennifer,
Re: Small Basket Photo Article
Shawn - in ID
>Great step-by-step. Thanks!
Page 2: last photo caption: "Sanding ... sanding ... and sanding .... *cough* cough * cough*"
GET SOME RESPIRATORY PROTECTION!!!!!
Matthew
>very cool. i enjoyed the tutorial and saved a pdf of it :)
nice work'
I'm impressed!
Jennifer@Indy.USA
>Andrew that is awesome! You put a ton of work into this. Okay....this will be a challenge....but I'm going to have to try one of these!
Thanks so much for putting this together. What kind of sanding doo-dad is that you're using on the Dremel? Is it a home made thingy?
Jennifer
Mike Rubes, Apex, NC
>Hi Andrew,
That's a very thorough and well done tutorial. Thanks for the inspiration!
Mike
Weekend of soccer coming in Apex, NC!!
Andrew Hilton
>hehe No doubt. Should've seen the ball I coughed up after a two day session with some Osage Orange! Yum.
Re: I'm impressed!
Andrew Hilton
>Nah, I do a lot of these articles and product demonstration stuff. It goes pretty quickly, actually. The videos take some time editing, though, but I didn't do a video of this project.
I'm guessing you mean the flat sanding disk and not the drum sanders. It's a mandrel that has a flat black plastic top to it. Fits the dremel perfectly. I just take some closed-cell foam (that one is just an old soda can cooler that I cut up) and glue it to it. Then I take a thin piece of leather and glue to the top of that. Then I stick the sandpaper to the leather. I used to stick the sandpaper to the foam but the foam doesn't last long when taking the paper off of it.
It's just a tiny, homemade power-sanding pad like the larger versions. Not sure where you can find the mandrel though. I get these made for me. Probably a Dremel dealer would have something similar?
The project isn't all that hard to do, I found out. Takes a little time with the complicated handle but then I'm no carver. Larger versions would work better as you actually have room to work and can use big-kid tools.
