Central Machinery Lathe. Help Needed!
John, NY
>Hi Guys and Gals
been around on the handtool forum for a while but real new to the turning side. Thought I was getting a good deal with a 10"x20" Central Machinery lathe @ $25 the other week. Bought sight unseen and of course turned out to be 'not a real bargain'. Broken/missing speed change mechanism and no belt. Can probably change the speed by hand but can't get away without a belt. Harbor Freight tell me the lathe was discontinued in 1999 and they no longer stock parts, go away. Any ideas where I might get a belt [if I can get a length by measuring my pulley setup]? And maybe even a manual etc...
I am only looking at making drawer knobs and the like out of the more exotic woods that I can't buy, nothing too fancy... course I haven't tried it yet and I did get hooked on this woodworking thing to start off with...
Thanks
John
Re: Central Machinery Lathe. Help Needed!
Re: Central Machinery Lathe. Help Needed! *LINK*
Andy in Raleigh
>You can get a link belt and it will be quiet and adjust to any size. I hate to send you back to HF, but that's an easy one to reference:
link belt
should have also asked... *LINK*
Andy in Raleigh
>How much it looks like the item referenced below on eBay. It is actually 21" x 10.25", but I would not be surprised if it is the discontinued HF/CM lathe under another label. If that is the case, you might email the seller about parts availability. I have one of these, BTW. Got it brand new for about $80 delivered. Worth every nickel and a few more (but not that many). I want to upgrade, but it does serve me well. If that is the same lathe, I can make a copy of the manual (pretty short).
Rand lathe
Re: should have also asked...
John, NY
>Thanks Andy, that looks like the one.
4 speeds, box section steel 'bed', comes with face plate and also got a chuck with it too. Mine had what appears to be a speed change mechanism on the left side but I assume I can just remove the cover and move the belt from pulley pair to pulley pair by hand in order to change the speed.
Not sure the belt isn't narrower than the link belt you pointed to unless you know different.
Thanks will try the Rand tack too.
A copy of the manual would be great!
Andy in Raleigh
>Click on my name and email me. I will see if I can scan in the very brief manual. I can certainly copy it and snail mail it. It does not include info on where to get parts, though. It is obviously printed to be for whatever "brand" slaps a label on the lathe and sells it. That seller on eBay has been selling them for some time. Since I bought mine from him, I would be happy to inquire about a specific part as a customer of his. But we should hold off on that until you get the manual to verify that it really matches.
I think the belt is pretty much "regular" sized, but I will double check. If I ever break it, I plan to get another at the auto parts store. That's where I got one for my antique table saw.
John, NY
>Just checked the belt and I find that the lathe will take about a 1/4" belt width which is much smaller than the flex belt I put on my table saw.
Shame, I was hopin'...
Andy in Raleigh
>Odd. I replied to your email to let you know that the manual provided with the "Rand" lathe is actually the HF manual for your model when I looked close. Some of the pictures don't quite match mine, including the pulley assembly. My guess is that the "Rands" were cobbled together from leftover parts when HF discontinued the model.
Bill Howatt
>Go to an "industrial" belt store with your specs. They will probably have what you need.
Bill
Thanks Andy Barnhart
John, NY
>Just wanted to say thanks again for your help. Manual arrived Saturday. As you say it looks as though the vever at the front is just to take the tension off the belt. Looks to be a threaded rod.
I think i'm going to be looking at replacing the two pulleys for ones which will take a 3/8" belt and putting a flex link belt on. I think i've found a place in PA who has pulleys... i'll give them a try anyway. Again, thanks for the leg up, much appreciated. I hope to be turning soon!
