Chuck Jaws
Chuck Jaws
Chuck Jaws
Wayne
>Okay I am new to turning and have a Super Nova chuck. The two sets of jaws I have are the power jaws and the step jaw set.
Wondering what jaws most of you use and/or recommend.
Thanks
Wayne
Re: Chuck Jaws
Brad Vietje
Re: Chuck Jaws
Brad Vietje
>Wayne,
I have the SuperNova and also use a Oneway Stronghold. On the SuperNova, I use the 50mm standard jaws the most, and I use the 100mm smooth dovetail jaws for larger objects, and taller hollow forms.
I also use the 35mm spigot jaws for turning tops and smaller diameter spindles. I have a very inexpensive source for Beech, Maple, and Ash dowels that are 1-5/8, which is just a tad too small for the 50mm jaws, so the spigot jaws work perfectly. They are also much thicker and more rugged than the 45mm spigot jaws.
I now use the 25mm jaws only for turning small dowels, delicate spindles for Christmas ornaments, and making tiny tops from pen blank-sized turning squares. I used to use them for expansion into small-footed bowls, etc..., but I now reverse nearly everything I turn between centers, so I use a tenon (which I greatly prefer)and the larger jaws, then turn the excess wood away later.
I have the cole jaws, but don't make many flat-top functional bowls, so I hardly ever use them. What I really need is a second Nova-family chuck.
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Chuck Jaws
Re: Chuck Jaws
Wayne
>Hi Brad,
Thank you for the information, is is greatly appreciated. There are so many choices, wow.
I looked at the Oneway stronghold, but there were more choices available for chucks with the Nova at our local store.
Thanks again,
Wayne
