Stuck Morse Taper
Stuck Morse Taper
Stuck Morse Taper
John Stankus -- Texas
>Any suggestions on how to get a Morse taper unstuck. I have a Jet Mini lathe, for which I just bought one of the expanding collet chucks from Lee Valley. Played around with it a bit and turned a chunk of oak branch my brother gave me. Afterwards I could not get the MT of the chuck out of the lathe. Any suggestions?
Thanks
John
Re: Stuck Morse Taper
Don Orr
>Usually you would just carefully tap with the knockout bar from the handwheel side like you do to get a drive center out. I imagine you have already tried this though.Maybe with a softer rod like brass, so you don't damage the collet, you could "tap" a little harder. Good luck.
Joel Hunnicutt
>I had a badly stuck MT awhile back. Tried banging on it, no luck, put in some penetrating oil, nothing, finally in desperation, I wraped the spur dive in cloth and gripped it with chanelocks and it twisted right out. Hope it works for you.
Joe Herrmann
>I had to do this once too. After you get the MT out of the lathe, go over both the male and female portions to determine WHY this happened. It should'nt do that and there has to be something--a burr, a scratch, foreign material--to cause this.
Good luck!
Joe
I that the one with the slits
Fred in NC
>and a drabar that screws into the small end of the Morse taper?
One thing about these is that it is very easy to overtighten it. Also, if you try to remove it with the regular knockout bar, it can and will damage the internal threads.
If this is the case, I would first apply some penetrating oil, and then screw in in the draw bar all the way, and back it about a turn. Then tap on the drabar with a mallet.
Compressing the expanding end of the collet with a vise grip can also help.
Hope this helps
Fred
Fog Tanner
>Since its a mini-lathe, you can tip it towards the tailstock end pour some household vinegar down the shaft. This should loosen up the stuck drive. Got this from one of our club members who had a stuck drive on a large lathe. Beat on the thing for hours, another member came over and used the vinegar and the drive spur fell out.
Phil Joines, Krum, Tx
>I use compression chuck a lot. To get them to hold on metal a fair amount of force is necessary. The draw bar sticks out past the hand wheel end about 2". To get them out I screw a threaded rod coupler nut half way on and hit it with a steel hammer. Make sure the draw bar is threaded into the collet at least 6 turns so it won't bugger up the threads.
Compression chuck or collet ...
Fred in NC
>This is about Morse taper collets, that are one piece. They look like a dead center, with a hole in the large end, and 4 slits around.. The small end is interanlly threaded for a draw bar.
These collets are intended for METAL work.
Collets are made to fit a work piece that is not too far off in size from the nominal size. That is, just a few thousands off. A 1/2" collet is probably about .504 or so when open, and will close only to about .496 or so.
Trying to compress a collet beyond its intended range will require too much force on the drawbar, and it will probably stick in the Morse taper. It could even damage the spindle's Morse taper.
I seldom use this type of collet for wood work anymore for the above reason.
Re: Compression chuck or collet ... *LINK*
>This is a link to the Lee Valley catalog page for the expanding collet chuck in question. If that helps clear up the problem I am having. The #2MT is a slip fit in the head stock. Do I need to remove the screw and the expanding collet pieces and then try tapping (pounding?) it out.
John
http://www.leevalley.com/wood/page.asp?page=49410&category=1,330,49238&abspage=1&ccurrency=2&SID=
Fred in NC
>John:
OK, that is not the kind of collet chuck that I was talking about.
You have a solid Morse taper and no drawbar.
Sorry !
RevDoug
>Use your knock out bar and give it a rap or two with a hammer. If that doesn't work pretty quickly, smack the snot out of it.
Turn 'em round,
RevDoug
It works every time.
Russ
>What nobody has mentioned is the sure way to break loose a stuck taper. Most of the time it can be easily broken by locking the spindle and twisting on whatever is stuck. If that doesn't work, give it a hit with a STEEL hammer while applying twisting pressure.
Then find out why it is stuck. The problem is usually rough machined surfaces on one or both parts of the taper. A good Morse Taper is a precision ground surface. A lot of our woodturning attachments aren't. Smooth out the rough ones with some sandpaper, used with oil lubricant.
