Phenolic Resin Sheet
Doug Leite
>Aloha, everyone,
I use some 1/4" thick Phenolic Resin sheet that I bought from Trend Lines years ago to make inlay templates. Trend Lines is no-more, so I am asking here if anyone has another source for this material. I bought it in 12" squares, but any size would do.
Mahalo
Doug
Re: Phenolic Resin Sheet
Re: Phenolic Resin Sheet *LINK*
Fred in NC
>I found it using Froggle ...
"phenolic sheet paper impregnated"
This one is expensive !!! $21. sq ft
They do sell online.
Do you really need 1/4" thick ?
Hope this helps
Fred
Phenolic sheets
>Doug
Highland Hardware in Atlanta used to sell them. I'll try and dig through the catalog and see if they still do.
Re: Phenolic Resin Sheet-thanks
Doug Leite
>Fred, When I did a google search, I came up with lots of manufacturers that would quote you or refer you to a distributor. Thanks for your link. I also posted this on the flat side and and was referred to MSC. They had a betterprice. Then my brain got in gear and off of the "Wood" only sources, and I went to MacMaster.com and they give it away @ $8.58. a sq. ft. No sense searching any farther, I will order from them.
Thanks for your input.
Doug
Re: Phenolic Resin Sheet Thanks
Doug Leite
>John,
Thanks for your offer, but I think I have found the best source for it.
Mahalo
Doug
