Dust hood
Dust hood
Dust hood
Harv
>Dose any one know of a good dust hood to buy or to build?
Thank you Harv
Re: Dust hood
Re: Dust hood
Shawn - in ID
>Hi Harv, I remember your question from a couple weeks ago about dust collection. Sorry nobody answered you here on the forum; I was interested in the responses. I'm buying the 3M Airstream personal unit (really pricey but worth it in the end). I don't know about dust hoods but am saving for a cyclone dust collector. While saving, I'm trying to pick among the Woodsucker, an Oneida 2hp, or buying the parts to Bill Pentz's design. You can read Bill's info (all you ever want to know about dust collection) on his site at: http://billpentz.com/woodworking/cyclone/index.cfm
You the cyclone that I refer to as his design I'm considering through: http://www.clearvuecyclones.com/
Your previous post was about the Harbor Freight 2hp dust collector. I don't know about it. What I can say is that the most important issue is what goes into your lungs - that's why I'm getting a good personal respirator first. I'll get the cyclone as soon as I can afford it.
Good luck!
Re: Dust hood
Re: Dust hood
JamieDonaldson
>Here is a good cheap and functional dust collector hood that is connected to my Delta DC. It is an off the shelf item from home heating/ cooling ducts, and draws the dust away from my face by placing it behind the lathe work area.
Re: Dust hood
Re: Dust hood *LINK*
Jack Diemer
>I just ordered the $9.99 lathe dust hood from Harbor freight. The price is right. I would rather it be a 6 in fitting, but its cheap and should do the job fine.
Lathe dust hood from HF
Re: Dust hood
Re: Dust hood
gary clarke
>Jamie, how did you attach your dust hood to your lathe?
Re: Dust hood
Russ's Hood....
W.C. Turner
>The cheapest solution was the pic that Russ posted of his dust hood! I couldn't find the pic, maybe he, or some one else will chime in with the url for it.
Re: Dust hood
Re: Dust hood
Fog Tanner
>I started out with Russ's most excellent idea for a dust hood. I have the 2hp Onedia with metal pipe running along the wall that my lathe is on. A box worked, but I needed the feed to come in at a different angel. Going back to the box idea, I took some large sheets of cardboard that some of my machinery came in and laid out a box with an angled side. Alond the way I had picked up a jumbo sized "scoop thingie" at a woodworking show. I beleive it was origianlly design for a radialarm saw, and came from Pennstate (I think). This became the angeled side of the box. I cut and folded the cardboard, and used some hot glue and duct tape to make a "custom" boxhood. A lot better than the ones you can buy.
When I went from a 16" to 24" lathe, I did the same thing - except I used the cardboard layout as a pattern and made one from plywood. I was happy with the design decided to commit it to ply. The advantage of the plywood hood is now I have a place to set my chuck key, something I got used to real quick. I also have a table behind my lathe which makes it real easy to place the dust hood.
