Woodcraft Spindle Steady Rest?
Tony - Memphis
>Has anybody tried this? Its on sale in their current flier for aorund $35. I was turning a spoon the other night and this thing was flopping around like crazy! Anyway, this one looks like it might be good for small stuff.
Thanks,
Tony
Re: Woodcraft Spindle Steady Rest?
Peter Teubel
>I have one. Works OK, good for narrow necked hollow forms. But the Oneway spindle steady rest is FAR superior for long thin spindles. I borrowed one for a turning job and proceeded to buy one after the job was finished. Worked great!
Keith Tompkins
Keith Tompkins
>Hi Tony, it's easy to make one, just use roller blade or scooter wheels. I use mine all the time.
What if...
Tony - Memphis
>I'm only going to use it for smaller stuff? I was thinking the smaller wheels would be better than the home made version (like Dominic's) using larger wheels. The Oneway wheels look fairly large too (nice design though). I turn spoons, furniture legs, etc. Thanks for the help.
Tony
Keith Tompkins
Re: What if...
Keith Tompkins
>you could try the inline skate wheels, even roller skate wheels. They give a little, which is a nice feature. Dom's as well as my steady use the larger scooter wheels.
Re: What if...
Peter Teubel
>Long spindles? Furnature legs? The Oneway is much better. The wider wheels will mark up the wood ALOT less than the small bearings of the Woodcraft rest. In addition, the Oneway almost centers itself while the 3-wheel one has to be futzed with more.
Thanks
Tony - Memphis
>Wonder if the Oneway will fit my Jet mini?
Tony
Re: Thanks
Peter Teubel
>Yes, it will.
Doghouse
>Tried it, returned it. I was using it to turn a cane. The "arms" could not be locked down reasonably and tended to slip and wander under slight vibration. Wheels left dents as they are metal. Not intended for larger stuff. May be good for spoons.
