New Walnut segmented bowl
Mark Kauder, Phenix City, AL
>Here is new segmented bowl that was started on my Jet Mini, and finished on my Vega. It is 10" in diameter. Walnut w/ Maple, Ebony and Bloodwood. The only bloodwood is the layer under the veneers on the rim. There are 24 segments per ring, and each ring is 5/16" thick.
This is the first bowl that I have finished with Behlen's Stringed Instrument Lacquer. I only had to use 6 coats of lacquer - it builds much faster, and dries much faster than the Deft.
I know that I am falling into a rut with the same feather ring design all the time, but if I were famous, it would be called my Signature Style.
As always, Critiques Welcome.
My own critique? Techically (joints, etc) this is the best bowl I have ever done. However, I would not do the 5/16" rings again unless it was necessary for the design (like with the "Fire Raising" bowl) - in this case it did not add anything, and was alot more work - lots of wood wasted in the resawing. Also, between when I did the veneer on the bottom of the feature ring, and the veneer on the top of the feature ring, I bought more veneer. The new stuff was thicker. I did not see it until I was already well past it in the final turning. Got to watch that in the future. Originally the Bloodwood was the top of the bowl, but my wife felt that it was to bold a contrast the the basic Black and White motif of the rest of the bowl, so I added Veneer on the top to mute it. Not sure that the Bloodwood fits at all. I probably should have used Ebony as the top ring/rim.
This was my first use of Ebony, and it is great to turn and sand.
Thanks,
Mark
Re: New Walnut segmented bowl
I like it Mark!
Dominic Greco in Richboro PA
>Mark,
What can I say? I like the shape. If it works for you, stick with it!
That finish is AWESOME! Can't wait to get some of that instrument lacquer and try it out.
BTW, thanks for all the tips. I think I may have actually had a good spray finish session last night. Before I packed it in, I looked for drips in the finish and saw none.
Later,
Dominic
Chuck Ludwigsen
>Mark. Excellent piece. Form, design, choice of materials - all great.
I see your point about the change in the veneer thickness. And I agree, it helps to not have to buy more from a different lot in the middle of a piece.
I like the red counterpoint of the bloodwood. And your wife was right to have you mute it with another veneer layer. As it is now, it seems to me to cap the piece nicely.
I also hope you don't move away from the thin segments too soon. I think it makes the lower portion of the piece - being 1 wood color and grain texture - to flow more smoothly instead of being boxy.
I hope this helps. You turn some beautiful segment work.
Chuck
Mike Schwing from Md.
>Well, if it is a rut then it is one you should stay in. Your work is more than remarkable. The finish is quality is something everyone should strive for.
I never would have noticed the thickness issues you brought up, and I like the look of the walnut segments, too. The only thing I see, critique wise, worth mentioning is that the profile appears to make a not too subtle change of direction about 3/5 of the way down, when that change could have been incorporated into the overall profile a little more seamlessly. As it is, I had to look three times to make sure it is really there, so it is very slight. Only a turner or a critic would notice it, so take it for what it is worth.
Great work. As I said before, glad you enjoy doing these things, I'd never have the patience for them.
Ron in Drums PA
>Once again - Beautiful!
As to the 5/16" rings, well I like them a heck of allot better than the 3/4" rings I see allot on other segmented turings.
If you think you are in a rut, try staves!
Denis Lalonde
>Mark...Nice looking vessel...What is the size??Must be over 900 segments???
Mark Kauder. Phenix City, AL
>10" diameter.
I never count the pieces - never. To get Zen on you - it has exactly as many pieces as it needs.
But 832 pieces including the veneer layers which are one piece each. But I did not count until you asked. ;)
Mark
Really Nice!!
RevDoug
Re: Wow Thats sweet
Phil Lieberman
>Nice job
