Hollowing Systems
Hollowing Systems
Hollowing Systems
Ron
>I need some help in getting started in hollow forms. I have a Berger tool and 3/4" holder and a Sorby multi-tip hollowing tool/shear scraper that I have used to hollow small boxes. I made a clamp to hold the 3/4" rod to a 1/4" rod so both rode on the tool rest without twisting once the Berger tool cut nicely.
I have been looking at the Jamieson and Kelton systems. Is this overkill for starters? If so what is better?
I have plenty of power and bed length, just don't know how to use it.
Thanks,
Ron
Re: Hollowing Systems
Re: Hollowing Systems *LINK*
Sean troy
>A captive hollowing system seems to work well for many. the i use is made by John Lea. see link. Best of luck and be safe. sean
http://www.woodturningtools.net
Jonathan
>You might want to read Lyn Mangiameli's reviews posted on Fred Holders page.
http://www.fholder.com/Woodturning/lyn.html
Its a very comprehensive look at whats available out there. I am trying to post a live link at the same time for you. Hope it works.
Whit Ballantine
>Lynn's review is indeed excellent. Just a personal observation here. I have been using the Jamieson system for about a year and a half and have been totally satisified with it. It is safe, easy and accurate. The only problems I have had with hollow forms using Lyle's sytem have been "operator" induced.
Whit
Donna Banfield
>I second the vote(?) for the Lyle Jamieson/captured boring bar for hollowing. I have it and love it. It keeps you from a serious injury while learning hollow forms. Further, if you want to you "know" how it works, use the system for the first few times to turn the inside of a bowl. It's a good idea -- you can see how the whole thing works.
Whit Ballantine
>Donna, hadn't thought of the bowl application but it makes sense. Thanks.
Whit
Pascal Oudet
>Hi Ron,
as Jonathan says, reading Lyn's article will give you a good idea of what is available on the market.
for hollow forms with small openings, Kelton scrapers give excellent results. for bigger HF, I would recommend Rolly Munro's tool, which is really good, works for (almost) all kind of shapes, and is not difficult to use.
hth,
Pascal
Ron
>Thanks for the information. Just got off the phone after ordering the John Lea system.
Ron
