Drill Press
Drill Press
Drill Press
Chris Alexander
>I purchased a Delta DP350 12" drill press. My question is can I use this to drill pen blanks and such?
Re: Drill Press
Re: Drill Press
Jerry Whitaker
>DELTA DP350
The DP350 is at the top of the line and comes with several features that make it worth its price. Variable speed is accomplished through two split pulleys that open and close as the adjustment dial is turned while the machine is running. The system is quiet, free from vibration, and so easy to use, you won't hesitate to change speeds for one special hole as you might be tempted to do with the other units.
With a 3-1/4-in. stroke, this machine will bore deeper holes than most table top models and there's a quill lock to hold the chuck at any height. The depth stop is a threaded rod with a quick-release nut for fast operation. It comes with an adjustable lamp that keeps the work area well lit.
It has more than enough stroke to drill pen blanks. It retails for $199 at Lowes but I bought mine on sale there recently for $139. I think they are still that price. A Bargain in my estimation
Re: Drill Press
Re: Drill Press
Tim McGill
>Chris,
Thanks for the review, sounds like a great drill press for my small shop. I may have to add it to my xmas list.
Question - When drilling the pen blanks, do you have any problems with runout at full stroke? I've experienced problems using someone else's drill press that resulted in a oblong hole on the top side.
Also, is the chuck capacity 1/2"?
Re: Drill Press
Re: Drill Press
John F
>are you using a brad point bit?
