Have a question? Ask Woody!
Still on the generator in mountains
TDaniel
>9" of rain and gusty winds did a number on my county, bridges closed, lines down, repair trucks unable to get to downed lines because of mud and steep hills (bad combination), log jams in creeks caused by all the beetle killed pines, an RV sales lot floated away jamming the bridge as well as a mobile home park; but the hurricane missed us. At least my phone connection still works. Don't count on me being here Wed night for the chat; it's a long shot.
TD
Re: Still on the generator in mountains
e
>... wow ... words can barely express any reaction to such devastation from the storm ...
so good to hear you're safe -- i want you as my neighbor in such a disaster ...
keep safe -- i'm sending you some sunshine
e
Glenn Hodges
>Sorry to hear about the mess you people are in Terry, we had it with Frances down here in South Georgia. Our power was out for 55 hours.
RonZ
>I'm glad to hear that you're haging in OK. Look on the bright side. There be an awful lot of lumber available. =o)
Re: Problem with lathe motor
Barbara Gill, Remlik Virginia
>Last year after Isabel left us without power I was afraid to use the computer while on generator power because of fluctuations in the power level. Was I being over careful?
>Bargara,
If you run your computer with a battery UPS backup system (as I always do) and a surge protector, your power supplied to the CPU and Monitor will be "conditioned" and steady regardless of the power source. It will also run a modem so if the line is active even though the power's out, you will still be able to "get out" (provided the ISP or backbone doesn't crash)
Mark
Thanks -e-
TDaniel
>We are making it fine; like the song goes. "a country boy can survive!' Still no power but we are accustomed to loss of power for days at a time so we have our own back-up. Propane water heater and stove as well as a wood cookstove and wood heat and the generator to power the well pump and refridge and freezer and recharge the flashlights. We don't bug the utility company; we're fine until whenever.......
We just saw the crews removing the fallen trees down our road; the electric company will have their crews out next so we may have power by tomorrow. Thanks for being concerned though.
TD
generator power
TDaniel
>Barb, I was told to make certain there was plenty of gas in the generator before using it to power my puter; seems the problem comes when the generator dies and the voltage quickly goes down. No problems so far.
TD
Dick Hines
Re: generator power
Dick Hines
>Glad to hear you are doing OK. We lucked out here. Not much wind and a lot less rain than they were calling for. Had 40 twisters rreported in the state but no one hurt and not much damage. We were lucky.
I went 8 days with no power after Isabel. We got a generator on the third day \but not big enough to run the hot water heater. Cold showers suck. I ahve a 10,000 watter on order. I will be in better shape if it happens again.
Be save and good luck.
James Brooks
>Well we do have power as of now TD. We had several tornadoes in Franklin Co. I have 5 big oaks blown over with root balls and debris everywhere. There were 25 houses and 20 chicken houses blown away about 7 miles from here. A woman was killed while sitting in here SUV and a 5 ft. Dia. oak blew down on top of her. About 6 inches of rain in addition to the 8 inches from Francis. I think we have had enough. I don't need wood that bad!!
Tip for generator and water heater
TDaniel
>Dick, you can disconnect one of the elements in your water heater when using it with the generator. It will take longer for it to recover but it will take a lot of the load off your generator. my 4500 watt generator takes care of my 1.5hp well pump and everything else I need. An electric water heater alone will take 4500 watts or more. I just filled my generator with the last can of gas; hoping power is restored before this runs out.
TD
TDaniel
>Glad you are ok JB. Winds here weren't that bad but the clouds seemed to get stuck at the mountain and just continued to rain for 2 days and then it didn't take a lot of rain to topple a lot of trees. Those all wheel drive bucket trucks are no match for mud and hills.
TD
Spencer Cone
>Glad you made out ok,TD. Sounds like things should be back to normal soon. On a side note I've been putting together a new sharpening jig to get the right grind on the bowl gouge. Should have it done today. Thanks for the advice!
Spence
Tks for the information Mark & Terry
