Steadies
Steadies
Steadies
JL work
>I just bought a Oneway Spindle steady after "test-driving" one on some chair stiles. It worked fine, and I was able to turn down to 3/8" on a 26" piece. They had a Oneway Bowl steady also. Anyone use a bowl steady? Is it worth the $90?
Re: Steadies
Re: Steadies
Fog Tanner
>I have one and have mixed feelings about it. I have used it on several bowls. On mesquite, I found it was more trouble to set up than any gain. On Cedar, it kept my fingers away from the bowl when it blew up. I will keep it for use on Cedar and the backside of large platters.
Oneway did advertise that if you had the Bowlsteady, you could buy the Spindlesteady head for $50. The base on the Bowlsteady is (was) different and they would sell the Spindlesteady head for the Bowlsteady base, but not the other way around. I don't know if they are still doing that, but if you want both you could return the spindle steady and buy the bowlsteady and spindle steady head and save $40..
Re: Steadies
Richard Allen
Re: Steadies
Richard Allen
>Hi JL
I have found the bowl steady to be a good product for thin platters, especialy when sanding. My procedure for bowls tends to eliminate the advantage of the bowl steady. But I have used the bowl steady on some problem sanding and the effect was quite good. The bowl steady is designed in such a way that I can swing it to the backside of the lathe to "store" it out of the way. Yet the bowl steady is only a few seconds from being in position to use.
If you get in the habit of turning and sanding well supported wood then the advantage of a bowl steady will be lost.
I am picking up a spindle steady I ordered a little while ago. It is good to know that it will work for the table legs I have planed.
Thanks
Richard
Re: Steadies
Re: Steadies
Peter Teubel
>I have both. The bowl steady come in VERY handy when I turn dried wood. It really does dampen the vibrations when the bowl starts getting thin. I never use it on green bowls, though. No need to. Vibration is rarely an issue there.
Re: Steadies
Re: Steadies
JamieDonaldson
>I occasionally use the Oneway bowl steady on vessels that need some support, and it works like a champ on my Stubby.
