something from the log dump
Mike Schwing from Maryland
>Silver maple taken a few months back at the local log dump. Roughed out then and finish turned about 2 weeks ago. 2 more weeks for finishing and here she is. About 6" in diameter, painstakingly finished thusly; sanded to 12000, sealed, sanded w/ 600. Then given 7 coats of Deft spray lacquer, sanded with 600 in between each coat, then sanded again w/ 600 and 1000, then buffed on wheels with tripoli and finally white diamond. Very glossy and smooth, but a lot of work.
I do not like the collar, but it is not glued on so I will make another. The lower rim is too thick and gives the appearance that it curves back upward. No problem, just another unused collar to add to the drawer full. They take about 15 minutes to make.
Comments welcomed, good/bad.
Re: something from the log dump
Sean Troy
>Mike, very nice as usual. Thats a prize piece of wood. Sean
Re: Wow Thats just so nice
Phil Lieberman
>I love that, the wood and finish is outstanding!!
Jim Shaver - Oakville, Ontario
>Hi Mike,
I do like the shape and my untrained eye likes the collar, but your finish is incredible and wonderful...did you dye the wood?
take care,
Jim
Frank Joseph Mantua NJ
>That is NICE Very NiCE I can't waite till I can do work of that class.
>Thanks Jim. Nope, no dye, the wood actually has that pinkish color to it. A bit of it might be in the photo but Mrs. Schwingding asked the same question upon seeing it emerge from the basement.
This wood was taken from the very base of a silver maple that was about 40" across.
I expect soon to be turning nothing but maple burl. I have a large shipment coming from Oregon in a few weeks that should keep me busy for 6-8 months, but I won't let the good log dump stuff go to waste.
A couple of questions
Loose Tenon
>Mike,
I've watched your work get better and better, you are doing a superb job.
You mentioned a few posts back that you had a captive system, complete with a laser. Is this a commercial unit, or one you made yourself?
I'm also wondering why you used the tripoli wheel when you sanded to such a high grade of paper/
Thanks, Loose Tenon
Ron in Drums PA
>Another beauty, you just keep on cranking them out!
Pic for Loose Tenon
>Here is a shot of my lathe with the hollowing rig attached. It is the commercially available Kelton system with the laser guide. I love this thing, but have no other system to compare it with. You can just barely see the laser dot in this pic. I'll hollow this cherry form out to about an inch and, wax it and let it dry before finish turning.
I use the tripoli compound because I find it forces the white diamond to do less work, and doesn't give me the chance to burn/melt the lacquer as occurs if I keep the wheels in contact with the work for too long. My approach with the tripoli is pretty much just to hit the form with whisper soft, and very quick passes on the wheel. Just enough to remove the sanding marks, more of just "scaring the form" by showing it the tripoli wheel.
Hope that helps. here's the pic.
Thanks Mike "NM"
Loose Tenon
Phil Lieberman
>Nice looking setup you got Mike,whats the reach with that 12" ?
Re: something from the log dump *LINK*
RevDoug
>Nice save from the dump. This is one gorgeous piece. Maybe if the collar had thinner edges. Only a thought though. I like it a lot.
BTW, I have the "cutting board" blank cut and glued up with a waste block, ready to turn. I just have to find the opportunity to turn it. I was going sto give it a go this past weekend, but I've got a sacroiliac (sp?) issue that is going to keep me off the lathe until I can get it straigtened out.
Keep up the good work Mike.
Turn 'em round,
RevDoug
Wood Spun Round
