Need for small tail stock
Dinyar Chavda
>I have been using the McNaughton bowl saver, and often end up having the wood hop-skip and jump out of the chuck, particularly when the piece is a natural edge bowl, with very uneven edges. A big center steady does not seem to help much.
What I need is a tailstock that is small enough (along the ways) so that it is not in the way of the handle of the McNaugton (which often cuts across the ways. I have a 2nd tool rest that can serve as the base for the tail stock, but can't dream up a way t oget a live-center onto the pole that I can put in this base.
Any ideas? Does this make anyu sense?
Re: Need for small tail stock
Doug Leite
>Dinyar
Make one.
I would get a bolt, drill and ream a morse taper socket into the end opposite the hex head to fit a live center. Also drill a knoukout rod hole thru this bolt at the same time. This bolt would go into a piece of cold roll steel (crs) that fits into the hole of that extra banjo (1" I assume). The crs shaft would need to be cross drilled and tapped for the bolt previously mentioned. The crs shaft might have to be larger then 1" and turned down to fit the banjo to accomodate the size of the mt on the live center. Example, if you used a #1 mt live center, the large end of the taper is about .475 (almost 1/2") so the bolt would need to be at least 9/16 dia. The #1 taper is about 2 5/32" long, so the bolt needs to be 2 5/32" + 1" for the crs shank + 1-1 1/2" extra for adjusting and a jam nut. This 9/16" bolt should fit the 1" shank but a 1 1/8" shaft would provide more strength in case of a severe catch.
If you want to use a #2 mt center, the shank is .572 (9/16 +) and the bolt would need to be at least 5/8" or 11/16" in dia. I would use a larger shank top dia. for this one, maybe 1 1/8" or preferably, 1 1/4" dia. and turn it down to fit into the baljo. The #2 mt shank length is about 2 5/8" long, so the bolt would need to be a little longer.
I hope that this is clearer then mud. If I was only a % as good as you with CAD, I would make a drawing. If necessary, I will attempt to do a rough drawing and e-mail it to you.
Have fun,
Doug
Peter Teubel
>Kelton Industries makes a tailstock specifically for use with the coring system.
Bob Elliott
>Dinyar,
It seems to me that you could not provide enough push simply by using a banjo with a live center vs a tailstock / live center.
How about if you got your tailstock back far enough so that the handle cleared it by using a #2 to #2 morse taper extension in your original tailstock / live center? Or possibly use two #2 to #2 morse taper extensions together to give you the necessary clearance?
Bob Elliott
>Or you could contact the Master of the McNaughton System, Mike Mahoney: latheguy@aol.com. He seems to have no problems with natural edge bowls!
Short Tail Stock
Greg Jensen
>An alternative is to use larger jaws on your chuck. I would recommend using jaws that will allow a tenon at least 4" in diameter and 5" would be better. If you go to a large tenon you will not dislodge the blank from the chuck. Then a tail stock will not be needed.
Ken Grunke
>Doug's idea is a good one. If you want to go with it, you can get a straight-shank morse taper sleeve instead of using a bolt, and boring the taper yourself. Here's a drawing I whipped up:
Dinyar Chavda
>Amazingly enough, it is clear, Doug! I say, amazing, because, usually, I cannot visualize something like what you are describing, but, for once, I understand what you are talking about. I don't know if I can make it, but I have a friend who might be able to help me if I decide to go that route. Thanks.
Dinyar Chavda
>I'll check it out, Peter.
Dinyar Chavda
>Bob, I understand the point you make re whether this can provide enough push, but it may work together with a steady rest.
The idea of pushing the original tailstock back doesn't work for me because there are times when the handle for the McNaugton crosses the line between the tailstock and the center of the wood.
Good luck over the next few days with the weather
