Ok heres another Cherry
Phil Lieberman
>9.5 x 4" sprayed lacquer and buffed
Re: Ok heres another Cherry
Phil Lieberman
Mike Schwing from Maryland
>Nice job Phil. Nice flowing curves. Isn't cherry a dream to turn? I just finished a few minutes ago forming a largish (12") hollow form from fresh cut cherry. Smells so great!
How many coats of lacquer went on there? Looks great. Any seal coat beforehand? How high did you sand it, grit wise?
Phil Lieberman
>Yes Mike, Thanks i just love Cherry, like you said the smell easy to work! I sanded from 60 grit not missing any along the way all the way up to 400 grit! And yes three of sand and seal than five satin lacquer all sprayed with that critter gun! sanding in between coats 320grit and steel wool
Dave MacLuskie
>That critter gun gave you those results? I may have to drop $40 on one. Think my utility pancake air compressor can handle it? The reqs looked pretty low.
Phil Lieberman
>3/4 hp compressor or larger that can produce 3 cfm @ 90 psi Yeap i have other gun and that low cost gun did that! Easy to use and clean and fast
Re: Critter
Phil Lieberman
Barry Turner
>My spray gun of choice is a Minwax poly spray can. Don't knock it. It gives great results. And I have a choice of satin or gloss.
