200+ woodworking book reviews
Double Egg Cup ??
Double Egg Cup ??
Double Egg Cup ??
Dan Faux
>Hi All
I have been asked by a relative to turn a Double Egg Cup that will sit on a short stem like a large goblet which in turn will sit on a small plate to hold the shells. My question is.. can it be done and any suggestions as to how.
any advice welcome.. thanks in advance DanF
Re: Double Egg Cup ??
Brad Vietje
Brad Vietje
>Sounds entirely do-able -- have you ever made a simple egg cup ? Basically a stout goblet made to the proper dimensions. To make one nested in a small bowl, just start out with a larger hunk of wood, create the goblet, then carefully turn the wood away to leave a stem surrounded by a small bowl. Making the bowl in a good, fine-grained hardwood in endgrain orientation will be easiest with a hook tool or ring tool -- or careful control cutting the inside of the bowl from the center outward with a small bowl gouge.
Another option is to make the goblet and bowl as separate pieces, with a snug fitting tennon, and then glue them together.
Safe spinnning,
Brad Vietje
Thetford, VT
Bert Workman
>What about a two piece solution? Turn the bowl and cut a recess that will hold the base of the egg cup stable. That way you could use flat stock the bowl and not need quite as big a piece to start with.
Please post a pic either way.
Bert
Dan Faux
>I may have not been specific enough about what concerns me re this request.. what he actually wants is an egg cup that will have two eggs side by side. My problem is how to turn two holes side by side in one piece of wood to take the eggs........sounds stupid when seen in print
thanks for your responses
Stuart Johnson
>I don't have any idea if this would work but...
Turn a cylinder that is large enough to contain the two egg cups. Then mark the centers of the cups and turn the hollows off center. Once they are complete remount the piece between centers and finish the outside. It would be much easier to convince them eggs over easy taste better.
Dan Faux
>Thanks Stuart
I'll try it on Saturday and let you know the result. About the over easy... here's me, new lathe, Vicmarc 175, just done an intensive one on one four day course and think I can turn anything...if only...
Dan
