Is this a Gloat?
Is this a Gloat?
Is this a Gloat?
W.C. Turner
>Went to the Nashville Flea Market today & ran across a New, Milwaukee Right Angle/Close Quarter drill. The vender had it priced $100 on one side, & on the other side $95. I said I'll give you $50. He said how about $75? I said I'll come back by before we leave. I returned, I said $60, & he said $65. Will it run? He plugged it in, Yes. Took it home for $65. BTW, it didn't have the manual with it.
I thought I had a gloat on the way home, & when I got there I looked in an old catalog. Found what appeared to be my drill. It was a Milwaukee 0375-6. Mine is an Heavy Duty Milwaukee 0375-1. But, both are; 3/8", 3.5 Amp, 55� angled chuckpaddle switch, double insulated , & double gearing. And, oh yeah, 0-1300 RPM. Then I looked at the Sioux model, (which I believe is also made by Milwaukee) right above the Milwaukee, & saw the speed was 0-2500, that's when I remembered that I should get the higher speed for sanding. Oh, and another drawback, it has a keyed chuck, instead of the keyless.
So, T.D., & all you others here, that use the 0-2500 rpm version, or Sioux version of this drill for sanding, Is this a Gloat, or am I the Goat?
Thanks,
W.C.
Re: Is this a Gloat?
Eaglesc
>Just check froogle
I/ve always wanted a drill like that for those times when...
Why would you want it for sanding?
TDaniel
>I use the 1300 rpm for sanding but I only powersand the bottoms and areas on natural edge vessels where I cannot sand by the rotation of the lathe. Occassionally I will powersand with 400, 600, or 800 grit to remove any marks left by the rotation. I do most of my sanding with Watco Natural Oil to minimize dust. The angle drills will get hot if used continuously so I use 2; one sanding and one cooling. Also, I found some 5" velcro backer pads in Orlando and these are working well.
TD
John Stegall
>Since I paid $75 including freight from E-bay with the same set-up as yours, I think you can gloat!
