A55 Smoothing Plane
help lathe face-plate removal...
Robert Case
>I am new to this...I have a JET 1236 with a face plate, and I can not remove it.....I want to make sure that I am turning it the correct way.... is it a regular thread or reverse thread-to unscrew(take it off)- clockwise or counterclockwise?
Thanks,
Robert
PS: My first bowl came out well....
Re: help lathe face-plate removal...
>Turn in counter clockwise to remove it.
I removed it !!!! NM
Robert Case
>I removed it !!!
Joe Herrmann
>I'm not that familiar with the Jets, but I would ASSUME that you would turn counter-clockwise to remove the faceplate. However, to prevent this from happening in the future, you can purchase a nylon washer to put between the spindle and the faceplate and it will prevent the faceplate from seizing up. Craft Supplies sells them--at least that's where I got mine. Or, I have read about folks making their own from the side of a plastic milk jug.
Joe
Thanks John! NM
Robert Case
>Thanks John !
Margarine container lids too
Bill Howatt
Ron in Drums PA
>I also have a 1236, to prevent this problem from happening I place a cardboard disc before I place on the faceplate.
