gloat - Pen Press..... *LINK*
Fred in NC
>I have been using a homemade pen press made from an old hand drill stand, the kind that you put a hand drill on, and it works like a drill press.
Recently I ordered a close-out item from Grizzly, their item G9839, Hand Punch Press. It came in today (4 days UPS regular !). Cost $13.95 + $5.95 shipping.
This item seems to be more adaptable to the needs of a pen maker than anything I have seen before, even a regular arbor press. It has bolts that can be adjusted to limit the travel, a hole with set screw for a ram, and threaded holes to locate the poly or wood base for the pen barrel.
I am going to make a 'ram' from UHMW poly, and a base with a little hole in it for the pen tip. I will post some pics later on.
Grizzly told me this morning that they have a FEW more units available.
Arbor press
Re: gloat - Pen Press..... *LINK*
Jack (Turtle Workshop)
>They still have some left. I reduced their inventory by 4. I got one for myself and 3 to be used as door prizes at our turning club.
Jack
SWEEEET...!
DW
>Fred..... thanks for the info. Just ordered one for the same reason! No more vice pressing for me!!
DW
Re: SWEEEET...!
Joe Herrmann
>I've always used my drill press to assemble pens. I put the head of a bolt in the chuck jaws and use it just like an arbor press. Works great.
Joe
Re: SWEEEET...!
Tom Mullane, Hagerstown, MD
>Been using the same press and love it... it is soooo much easier to assemble a pen in the verticle position than in horizontal....
Thought about doing that...
DW
>... But I like to keep my stations set up for production... unfortunately, I have a jig for drilling the blanks on the drill press and don't like to RR the darn thing if I don't have to.
Great idea though...
Now if only there was a mandrel that eliminated the tendancy to flex.... biggest issue though is quality control on the ID of the brass tubes...
DW
Eaglesc
>I just got off the phone with Grizzly and ordered mine.
I didn't read far enough into your poat to see that you also posted the link.
The item number you posted is off by one digit.
I tried the search at grizz and kept coming up with a set of blades.
The correct # is:
G9839
Of course if you use the link it won;t be necessary.
Thanks for the tip!
(I've been using a Bessy Clamp and have had a few blow outs!)
Eaglesc
>G0938
You gat me doing it!
