Have a question? Ask Woody!
Need measurement from Jet 16" lathe, please.
Al Crandall
>I have volunteered to make a couple of vacuum chucks for our club's lathe, but the building where the lathe lives is 42 miles from my house and I don't know if it would be open to give me access to the lathe even if I drove there to measure. The lathe is the new Jet 16", and I need to know the length of the spindle from one end of the bore to the other. Also needed is the distance from the inboard end of the spindle to the shoulder at the end of the threads where attachments seat.
All my chucks utilize a threaded lamp rod fitted inside the spindle to make the connection between the chuck and the rotating connector on the outboard end of the lathe. The length of this rod is what I am trying to determine. Any and all help would be appreciated. Al
Re: Need measurement from Jet 16" lathe, please.
Richard Allen
Richard Allen
>If you don't get an answer then just cut it on site at the next meeting. The lamp tube cuts easly enough with a hacksaw. Shouldn't take you more than a couple of minutes.
Bernie
>AL,
I HAVE THAT LATHE 1642 AND MADE A VAC CHUCK ALSO I WILL MEASURE MY ROD WHEN I GET HOME AND LET YOU KNOW.
Re: Need measurement from Jet 16" lathe, please. *LINK*
John U - NC
>Hi Al,
here are the measurements you need:
length of the spindle from one end of the bore to the other = 15.5"
distance from the inboard end of the spindle to the shoulder at the end of the threads where attachments seat = 1"
Mine is set up the same way, using lamp rod, and home-made adaptors ---- I have a series of pictures at the link below if you're looking for ideas....
John
Jet 1642 Vacuum attachment
Thank you so much.
Al Crandall
>The project went slower yesterday than I had planned. I was out of welding rod so I couldn't finish the face plates for the chucks, and by the time I got ready to go back out to the shop, it was time for the turning chat room. All is well this morning, thanks to you. Al
I cut mine 16" NM
Bernie
Don Orr
>John, that is excellent! Also kind of interesting timing as I am in the process of setting up the same thing for the same lathe. Your photos help very much. I like the idea of using Corian at the rotating junction-no leaks and the rod threads in tight! Thanks so much for your information.
Don
Jet 1642 vacuum pump setup *LINK*
John U - Charlotte, NC
>I posted a message last year when I set it up, giving a few more of the details. I had a problem with the threaded corian on the faceplace stripping, and I ended up turning a small recess in the front side of the corian faceplate, and added a brass lamp rod nut on the face in that recess.
Hopefully the following link will work for the archived file.
14 May 2003 - Vacuum Pump Setup
My solutions for the thread stripping problem.
Al Crandall
>Hi John. In the BP Archives is an article which I wrote documenting my methods of constructing rotary adaptors for vacuum systems. I have always tapped the "bell" or chuck from the back side with a 3/8 pipe tap and inserted a brass 3/8 to 1/8 reducer bushing so as to have tapered threads for screwing the lamp rod into. On this latest round of chucks, however, I am using a lamp rod connector in place of the tapered pipe thread bushing. I think the straight threads in the connector might have some advantage. The leak around the straight threads, when compared to the tapered thread used before, should be minute. It will certainly be less than that imposed on other systems which depend on the "seal" of the chuck to the spindle threads.
Al
Guest
>Very interesting. I'm going to be making a few vacuum connectors and chucks in the coming months for a friends' and a clubs' Jet 1642.
Except, I'm going to be making it so that it replaces the handwheel instead of the inside hollow rod. Far less hassle when you need to use the spindle taper for something. I've made a several now of each style for other lathes (see the link) but not the Jet 1642.
Mini Vacuum Chuck System
