Uses for McNaughton & other savers?
George Van
>I have the McNaughton bowl saver. I can core out bowls with it but I was hoping others have found other uses for the savers that I do not know about to make the set more useful and versatile.
Any ideas?
Thanks, George
Re: Uses for McNaughton & other savers?
The straight blade makes a great parting tool.
Al Crandall
>I was shaping the outside of a large bowl when I found a nail in the bottom half of the blank. The top half would make a deep platter if I could remove the damaged part containing the metal. I used the straight blade of the center saver to part off the offending chunk. Quick, safe, easy way to make a parting cut over 5" deep. I had no other options that I could think of short of going back to the chain saw.
Dave Peebles Lyons, Ohio!
>Hello George,
One of the slickest things I have seen anyone do with the Oneway system was done by Dave Lancaster at one of the symposiums.
He mounted a half log on the lathe and proceeded to just use the largest coring tool to make the largest outside shape on the bowl. No roughing it to a round shape, he just did it with the coring tool. It was very impressive to see.
I haven't tried it yet, but I will be trying it in the near future.
Dave is one of the best production turners I have ever seen, so he is always thinking of new thinks to try. If you ever get a chance to see him turn, do yourself a favor and do it. Plus, he is a heck of a nice guy!!
Best wishes,
Dave
George Van
>Thanks Al and Dave, both are good ideas and new to me. I will remember to see Dave Lancaster if I ever have the chance. I will try his method later today.
George
Bill Grumbine, Kutztown PA
>George, just remember, that if you do this, large chunks of wood are apt to go flying. I have done this in the past, so I know whereof I speak.
Bill
Tom Mullane
>Your kidding Bill... large chunks of wood flying off the lathe and bouncing around the shop floor... I would never believe it... LOL... If I hadn't seen it myself.. LOL...
George Van
>Yes Bill and Tom, I think you are correct.
After I had the section mounted between centers and started to turn slow I chickened out. I think this method is beyond my skill level. I will stick to my rough circle off the chainsaw and then the gouge between centers or a pin chuck.
Thanks, George
