Oliver outboard options
Bert Workman
>I feel a little dumb.
I've been turning on an old Oliver model 167 while my Jet has been in the shop. Just today I noticed that the hand wheel on the outboard side can be removed.
The wheel is about 9" across made of aluminum, and has pre-drilled counter sunk holes that look like they are made for face plate type work. Of course it is reverse threaded but that only makes sense.
Does this mean I can mount up a big piece of wood and turn it outboard? I can come up with a free standing tool rest, but how do I do things without a tail stock for reverse chucking etc? Is this a fairly common thing?
I have so much to learn.
Thanks to all,
Bert
Re: Oliver outboard options
Re: Oliver picture
Bert Workman
>Here is a shot of the hand wheel. I'm excited about the prospect of turning larger bowls but I'm not sure how I would finish them.
Re: Oliver another pic
Bert Workman
>Thanks for any advice or warnings about attempting to turn something backwards on the outboard side. Here is a shot of the countersunk screw holes.
I have really liked turning on the big old piece of iron. Very stable and it runs like a champ.
Keith Tompkins
Keith Tompkins
>HI Bert, I really like the older lathes, esp. the Olivers.
I would personally use the handwheel as a faceplate,it appears to be designed for that purpose. Also, Oneway makes a 1 1/8" adapter for their chuck which is threaded both directions. YOu could use that outboard on the Oliver as well.
Bob Hackett
>Bert,
Once you start turning outboard(or turn on a bowl lathe)you`ll wonder why you put up with working around the bed/tailstock all that time.
Reverse chucking can be handled by either a vac chuck,a jam chuck or a compression chuck.
The only real drawback to turning without a tailstock is that you need to be careful to solidly mount the blank for roughing as you don`t have that extra safety factor of the tailstock holding it.You also will find it hard to make small adjustments to the blank.
Once you get used to it I think you`ll find that extra freedom of movement and the extra support from not hanging over the lathe bed help to make cutting a fair curve easier.
T Daniel should be posting on this one soon as he is the bowl lathe king on this island.I`m sure he`ll have some useful input.
Mainely,Bob
Bert Workman
>Yes! suddenly all of the posts about plywood disks and plastic wrap from HF etc. come flooding back. Now that they apply to me I'll have to pay more attention.
Thanks, I love this forum.
Bert
