Re: What is the bare minimum required to turn a bo
MP Wall
>You got a faceplate with that lathe didn't you? If so then just a 3/8 or 1/2 bowl gouge and you are in business. Rough between the spur and live center, form a flat surface on what will be the bottom of the bowl, glue to a waste block attached to the faceplate, let the glue set, return the outside of the bowl and then hollow. Mind you that is quick and dirty and refuses to mention sanding as I hate it, but seem to do a lot of it. You sand the outside when turned true and then sand when you get the inside to your liking.
Good luck with the new addiction,
MP Wall
