THE WOODRAT IS BACK!
Broken belt, mini lathe *LINK*
Roly
>I have a 1994 10" Reliant Mini lathe, that was made in Taiwan, model DD70. It has a round belt fitted onto the stepped pulleys and it just broke and I can't seem to find another to replace it. Does anyone have a lead how I can obtain another. It looks like it is made of a stiff plastic-like material, and I don't think a rubber one like a vaccuum cleaner belt would work very well. Thanks in advance............Roly
http://gages-56.com/roly.html
Re: Broken belt, mini lathe *LINK*
Take it to a bearing and drive
TDaniel
>company and let them match it up. They also have kits where you can cut a piece to length and glue it together.
TD
Arch
>Hi Roly, I made a similar belt for my Carbatec knockoff by using spline material used for aluminum window frames. Use a lap joint, not a butt with superglue. Butyl O rings have been suggested. You might try sewing machine, key cutter and appliance repair shops. HTH, Arch
What size is it, anyway ?
Fred in NC
