Question for yo-yo spin
jim reasoner
>Your pens with the rubber O-rings are very impressive. I want to try that and need a little info. It looks like you cut a little groove so the ring will be about half exposed. Do you put any glue in the groove and do you apply the finish with the ring in place or is that the final step after assembly. Inquiring minds want to know!
Re: Question for yo-yo spin
YoYoSpin
Re: Question for yo-yo spin *LINK*
YoYoSpin
>Hey Jim, glad you like the pens...the whole idea is to make something that looks good AND is comfortable to use.
The groves are cut with a sharp skew, but one of those very thin parting tools could also be used. There is no glue holding the rings in place. The rings are common plumbing o-rings (Buna-N), purchased through www.allorings.com. The ID of the o-ring's I use run about 70-80% of the OD of the pen, so it�s a tight fit.
The o-rings are rolled onto the upper blank, and into the grove, as part of the final assembly process, after finishing.
BTW, we're in the process of putting together comprehensive pen-making how-to instructions through the www.penturners.org site for all the pen kits on the market. Check out the link below for our first cut at an instruction template...this is a first draft, so comments are welcome.
Cigar Pen Visual-Build Instructions
Re: Another Question for yo-yo spin
Charlie Romano
>I want to place an order for the o rings. Their site needless to say is rather intimidating. In a previous post (which I had saved), you had mentioned buna size 011 and also a red silicone ring.
If you were to place an order so that you would have a representitive supply in both colors and sizes for both pens of various sizes and bottle stoppers, what would you recommend.
Appreciate any help - thanks
Charlie Romano
YoYoSpin
Re: Another Question for yo-yo spin *LINK*
YoYoSpin
>Charlie, not knowing what kind of pen kit you're using or how you style your turnings, it's a little hard to answer that question. But, referring to the All O-Rings website size chart (link below), you'll almost certainly want rings in the -008 to -012 size range.
best regards,
Ed D.
O-Ring Size Chart
Thanks
Charlie Romano
