how to turn a handle
davidewhiting
>I need to turn some handles, what is the best way to get a perfectly aligned hole?
What is the proper process etc.
is there a link somewhere ?
TIA
davidewhiting
TIA
Re: how to turn a handle
Mark Kauder, Phenix City, AL
>Drill the hole for the tool first, and then use this hole for your live center.
Mark
>Mark's correct. I drill the hole first. I'll try to remember to look on my home computer. I used to have a handle making demo article there. If I do I'll post it.
Richard Allen
>Hi David
Drill hole first and mount the blank on a mandril so you know the hole is straight between centers (which isn't necessarly the same a the hole being centered and the center of the blank being at the other end).
The mandril should be just a little shorter than the depth of the drilled hole. The mandril can be made from a piece of wood held in a chuck. Make sure the hole end of the handle stock is square to the drilled hole (not necessarly square to the handle stock.)
Good Luck
Richard
RonZ
>It's kind of like how a congregant asked the rabbi how his sermons were always on target. The rabbi responded that first he shoots the arrow then he draws the target. =o)
As Mark said, first You drill the hole and then turn the handle. I use a cone live center on the side where the hole is. I then use a cut piece of brass pipe about an inch long for the ferule. I first turn a tenon on the side with the hole to match the internal diameter of the ferule. I then immedeatly put on the ferule and continue to turn the handle. This will help the hole end of the handle to keep from splitting.
Joe Herrmann
>Funny, I always turn the handle first and then drill the hole. I do it the same way I do when I purchase a tool un-handled and then have to drill the hole.
Usually I turn the handle and put on the ferule. Then I put the drill chuck in the headstock and fit it with an appropriate diameter bit. I remove the live center from the tailstock, mount the tip of the end of the handle in the hole in the tailstock ram, align the dril bit with the spurcenter mounting hole, turn on the lathe, and advance the ram until I reach the desired depth. I have never had any problems with the hole not being straight when I use this method.
However, all the others responses will work just as well.
Joe
Re: how to turn a handle *LINK*
Jean Michel
>Hi John,
You had it named: Turning tool handles.doc
You sent it to me quite a while back, I still have it and can send it back to you if you lost it...
HTH,
Jean.
My not so humble site...
>Thanks Jean I found it and e-mailed it too him. It did remind me that I built a tool handle and photographed the steps so I need to get on the ball and put the photos with the article. I'll try to do that in the next week or so and see if they want it on wood central.
All articles welcome!
Good technique.
>I've always done it the other way, but this makes the most sense for getting the hole aligned with the axis of the handle. Thanks.
Ellis Walentine, Host
