Fingernail grind bowl gouges
Dennis Taylor (Akron, Ohio)
>I took a green bowl turning class today, and now am in the market for a bowl gouge.... understand that a 3/8 gouge with the finernail/celtic grind is the tool to own....here is my question.. is there enough differnce between the tool from say Packard (there fingernail profile gouge) and Sorby to warrant the price difference?.... I am open to either, but just wondered if the cost difference is really because of the tool or the name?..... I do not recall the cost of the Packard tool, but the Sorby from Woodcraft is in the 65.00 range and Packard is close to 1/2 the price...tks for the input...had a great class today and eager to make some bowls now...Dennis
Re: Fingernail grind bowl gouges
RonZ
>Hi Dennis,
PAckard tools is actually Hamlet, they note this in their catalog. I own both Hamlet and Sorby tools and there is no justification in the price difference [unless you like fancy ash handles with a brass button on the end]. Go with the Packard/Hamlet tool and you'll be satisfied. I also prefer the Hamlet celtic/long grind as it's wings are swept back a lot which makes for good shearing cuts.
Good luck,
Ron
Dave MacLuskie
>Where do you see the Packards for about 1/2 the price of the Sorby's? The 3/8" fingernail/celt appears to be about 59 bucks for both the Packard and Sorby. Am I missing some deal?
Duane
>Hi Dennis I bought a new 1/4" and 3/8" bowl gouge from Packard at the 2004 symposium.Each was about $20.00 less than Sorby.Then Packard gave another 10% off.After using them I like packards tools better,it's longer, fits me more comfortably
>the turning class I was attending yestereday, I have a 1/4 bowl gouge, and had it shaped to a fingernail, but when actully using on larger pieces, will it didn't cut the mustard..the instructor lent me his 1/2 fingernail(Sorby) and it was a dream, I had never turned a bowl and I never had spirals of wood trailing off my tool..I was in turners heaven, I know it isn't much to most of you, but it was something to me..the Sorby was nice, just is it worth the 20-30 dollars more in cost?...Dennis
TDaniel
>Dennis, there are several things that affect which gouge and which size we should recommend. The size of your lathe, flute shape, handle length all have to be coordinated. If you have a lathe with a small swing, you need a short handle; If your toolrest won't go very low you will likely cut with the tip of the tool instead of the side so flute shape becomes important. A deep "U" shaped flute is the easiest to sharpen and ejects the chips much better than a "V" shape when cutting with the side of the tip; however, when cutting with the nose I don't know that it matters. As far as which brand, since you are just learning to sharpen I would go with the cheapest IF the flute shapes are the same. Take the money you save and apply it toward a jig to sharpen it with.
TD
>I have a Jet Mini lathe, and I do have the Wolverine sharpening jig with the fingernail profile attachment...Dennis
3/8" should work fine
TDaniel
Mark Kauder, Phenix City, AL
>Dennis,
I would like to suggest the P&N brand of tools. They are available from Lee Valley and Craft USA. They are only available unhandles, but they are as good as Sorby, but at a lesser price.
Mark
JamieDonaldson
>The P&N gouges have a flute shape that is more V than U like the Sorby. I find for my purposes the U shape is easier to sharpen and ejects chips better than the V shape. Buy the less expensive tools until you master sharpening, and then move up if you find a need based on experience.
Jesper, Denmark
Buy the flute, not the grind....
Jesper, Denmark
>Sorby and other charge more for the fingernail grind than the standard grind on the same tool.
Since you will be developing your own fashion of grinding anyway, there is no reason to pay the extra 10 bucks for the first grind on the tool.
Buy the standard tool and grind your own fingernails.
Re: Buy the flute, not the grind....
>Great Advice
Mark
