Watch out for flying wood...
David Hammond, in Powder Springs GA
>I spent my time here last night posting about last weekend's show - but I wanted to post yet another quick reminder for us all to be carefull out on the lathe...
I was roughing out a peice of Ambrosia Maple, that had several small stress cracks in the end grain, from felling the tree. I knew they were there, but dismissed them almost entirely, because I had turned more of this wood, and it wasn't a problem. I turned my dovetail and reversed the thick plate onto my chuck: two seconds into shaping the inside, at some 1300 RPM's, half the shallow bowl flew off the lathe, thudding into the wall quite soundly. Whew! That was enough for last night, and I just came on in: lesson one - I didn't have my face shield on, because I honestly just hate the thing when I want to spend a few minutes on the lathe. Lesson two - I'm thankful I was turning on a VB36, out of the line of fire... Had I been turning on any other bed lathe, that chunk of wood could have done some solid damage.
Enjoy yourself, but don't forget to look out guys and gals - anything can happen. If you can turn outboard, or at the end of the bed of a lathe with a movable headstock, try to do so, it's a lot safer...
David
Re: Watch out for flying wood...
John Bussom, Muncy Pa.
>Well David, I don't really like that faceshield either but everytime I put it on it helps remind me the whoopin I took the last time when I didn't wear it, turn safely!
John
Rick in Colgate, Wi
>I dont care for those face shields either, mostly because of reflective glare and static cling.
Got to thinking one day about those face masks that paint ballers use for protection. Cheap enough and impact resistant, plus they dont fog up. Anyone ever try one for turning?
Got to admit, it sure is scary when a bowl disappears off the lathe!
Bob Hackett
>Other than keeping you from getting badly cut,what is that thin faceshield going to do for you anyway if a large piece flys off?
David Lancaster is argueably the top production bowl turner in the US today.If he`s not the top,he`s in the top 3.He had a VERY serious accident when he was about to finish sand a medium size bowl,some of you saw the result in a past issue of the AAW journal.He now turns while wearing a pro hockey helmet with a full face cage.He also wears polycarbonate safety glasses.
Dave told us at a meeting that it`s just a matter of time before you get hit with something at the lathe.The question is,will you be able to get up and walk away from it.Dave nearly didn`t.
Mainely,Bob
>Bob, you are probably right about getting a direct hit from a large piece, a small 8" piece can do enough damage, I didn't get tore up really bad but a couple of cuts inside and outside of my mouth and knocked a little silly for awhile I'll wear the faceshield, it did protect me one time before!
I think if I would have had it on when I took the last hit my mouth and sinus wouldn't hurt every time I step up to the lathe, probably the same way David feels.
Now, I admit that I am real new to turning and have a lot to learn, but I don't want to learn the hardest way possible, I mean I don't need it beaten into my head, heck I even thought about gettin one of them flak vests :)
John
GeeSeaWhy
>David,
If you don't like the faceshield you have, buy another one. They're cheap compared to any kind of dentistry work or a few days in hospital. Mine got so scratched I bought a new one recently. I don't like the new one as much but I'll wear it. If I can't get used to it, I'll buy another or look for a replacement shield for the old one. Turning without one just isn't an option.
Graeme
