Glaser 5/8" Deep Gouge
Brad Bittle
>Could someone tell me if this gouge has a David Ellsworth grind, or can I sharpen it with the Wolverine jig?
Thank you,
Brad in Knoxville
Brad Bittle
Thank you,
Brad in Knoxville
Re: Glaser 5/8" Deep Gouge
Joel Hunnicutt
>It is a swept back grind but not as sever as ellsworth. Much easier to control in my mind. Yes you can sharpen on a wolerine. Great gouge.
Lyn J. Mangiameli
>Both use the same bevel angles and extend the wings back a comparable distance. The primary difference between the Ellsworth geometry and the Glaser geometry results from differences in flute shape, rather than external grind. The Ellsworth tools are based on a parabolic ("Superflute") flute while the Glaser is more of a rounded V. Folks have different experiences with the various flute shapes. I prefer the Glaser (as does John Jordan, as can be seen in his own gouges he now sells), while others prefer the more open flute shape. I like the Glaser because it gives a narrower point for detail work, is easier to maintain with a slip stone, and provides more mass behind the primary cutting edges. Most others who prefer the parabolic flute do so because they find it offers better clearance of shavings.
Either can be easily sharpened with the Wolverine, TruGrind, Kelton and even Tormek to match the original grind. You can also use David's own jig with either, (and adapt it easily to the Wolverine or even easier to the Kelton) but his jig only accepts a 5/8 inch shaft size.
Brad Bittle
>Thanks so much for the info. I have had the Glaser for a week or so, and do enjoy its cutting characteristics. I don't want to put it down when it comes time for the "finishing cuts"
Brad in Knoxville
Peter Teubel
>I also have one, but I use it for all the roughing. The edge holding ability is truly astounding. The edge really does last 4x longer than any of my HSS tools.
