Mr TDaniel
Dustmaker Mike
>On my way to work this morning I was thinking (I know scarry) about what you said last night during the chat. If I understood you correctly you said you had a few shallow gouges you could not sharpen on the Wolverian jig because they were to short. If this is the case why not use a piece of 2x2 drill a hole in the end and cut it to length to make the correct angle to the wheel. I think if you support it in the middle by makeing a raiser block with a "V" cut in the bottom
