Crotch Cutting (ouch!) Question
>Hello,
We had a heckuva storm blow thru last week and knocked a lot of trees over. A friend lost a large walnut tree and offered to let me cut and take what I wanted. (woohoo!)
I have one chunk where the trunk forks. How do I orientate my cuts to get the best figure for turning?
Tommy
Re: Crotch Cutting (ouch!) Question
>Take your cut-line through both piths and do it as a rip cut with the crotch on it's side so that the cut line is vertical.
Suggest you mount/turn with the piths at the bottom of the bowl(s) to preserve the most amount of figure in the bottom of the form(s). Deptending on size, you have the option of natural edge or cut rim.
Mark
Richard Allen
Re: Crotch Cutting (ouch!) Question *LINK*
Richard Allen
>Here is a like to an answer to this question from a previous thread.
Answer in previous thread
Re: Crotch Cutting Error, Maybe
>Tommy,
The previous graphic seemed to illustrate cutting the piece by standing it on end and then cutting down from the two ends of the "Y". That's not going to work with a chain saw unless you're using a rip chain WHICH MUST NEVER BE USED IN A HAND-HELD SAW (made for sawmill saws ONLY).
Using a full-comp, semi-skip, or full skip chain, you should be cutting with the Y "standing" on one side. You will usually have to brace both sides with other log bolts to keep it standing. The cut will yield the long ribbons you get when doing a normal pith-cut in a straight log. You can cut a section that's longer than your bar, but alternate cutting from each end, and be mindfull of kickback if/when the nose get buried. Be sure to keep your sprocket clear of shavings to avoid overheating the chain and clutch.
Eye and ear protection wouldn't hurt either.
If you come to Bill's this year I'll be cutting at least one crotch piece like this.
Mark
Richard Allen
Richard Allen
>Hi Mark
The drawing is a bit misleading. The line of cut is shown clearly enough. I guess I thought anyone useing a chainsaw would know a safe way to use the saw. Of course anyone can find an unsafe way to use most any tool.
Thanks
Thanks all! Big help. :-)
Barbara Gill, Remlik Virginia
>Mark, my husband uses a rip chain with a 36" bar to split logs lengthwise all the time. It is the best and most efficient way to split them so they will fit on my sawmill. A traditional chain will not give as straight a cut.
On occasion we stand a log on its end (with the tractor) to make splitting easier. Of course the log is a monster and its weight holds it in place. A small log would have to be secured.
No Picture
>I posted a picture with the above post. It showed up in the preview but not in the post.
Re: Rip Chain
>Barb,
I'll not dispute a trained and experienced professional's option to use of a rip chain on a free-hand saw, but for those of us who don't try to make a living in the lumber business, I think my statement stands.
These machines are, despite Hollywood, far more dangerous than average people understand, and the huge number of injuries each year is testiment to that. Far too many "think" they know far more than they actually do.
Mark
Re: Rip Chain
TDaniel
>Rip chains are hard to sharpen but are not more dangerous than other chains. A skip tooth chain is a better choice in most situations. Cutting in line with growth rings is always a problem; a slight angling of the saw will solve the problem of long curls that will not break off. Technique is the key rather than equipment. As far as the proper way to cut a crotch......experiment. There are several interesting grain patterns that can be obtained; splitting the "Y" is one way but there are other interesting ways to cut a crotch. Try all options and see what you get. Nothing beats experience so go for it.
TD
Re: Rip Chain
>I guess I better clarify something for anyone who does not know Dan my husband. :-) He is definitely not a trained professional lumberjack. He is a farmer and a Pitmaster and a really good cook. He just happens to be able to cut a nice straight line with that big chainsaw; a skill I don't particularly want to develop. I will stick to my smaller chainsaws. :-)
One more thing I should clarify is that I really don't make a living at my sawmill it is somewhere between a hobby and a profession but not really either. :-)
I don't dispute that chainsaws can be dangerous especially when in the hands of someone who doesn't have a clue. I just wanted to clarify that your statement that a rip chain should never be used in a hand held chainsaw was not exactly accurate. As Terry said above, the proper use of one is really no more dangerous than using a crosscut chain. The key here is proper use.
Another option
Gary Evans, Tallassee, TN
>If the crotch is big enough, and you want a nice blank for a hollow vessel, you can lay the crotch so that the plane of the Y is parallel to the ground. Cut down through each pith to make a V shaped blank that will have crotch figure on two sides. This works really well when you find a crotch with 3 or 4 branches.
Gary
Re: Rip Chain
>Understand, Barb (and Terry).
But every arborist and saw & chain vendor I've personally spoken to has told me without hedging that rip chain, the kind with alternating top-plates ground off the cutters (sometimes called "Granville chain"), is not to be used hand held.
Mark
More than one kind?
TDaniel
>Mark, the ripchains that I use are of two styles. One is merely a skip-toothed chain (extra blank links between teeth, equivalent to using a 24T blade on your table saw for ripping instead of a 60T); the other has a left side cutter, followed by a right side cutter, and then a straight tooth to pull the shavings out. I have only bought one of these ripchains because they are difficult to sharpen and they do not cut any better than a skip-tooth. I have seen another style of ripchain but have never used that one. Cutters on it were not at all similar to a conventional chain; I think this may be the one you are referring to. The important thing about chains is to always have a minimum of 3 teeth engaged in the wood. Also, it is important to tilt the saw slightly so that you are always crossing some growth rings. Whenever you saw in perfect alighnment with growth rings the shavings will not break off and will quickly jam the sprocket cover. Slightly tilting the saw will take care of this problem.
TD
Re: Oh, Yeah
>I've heard many people refer to skip tooth (either half or full skip) as ripping chain, but that's NOT what I'm talking about; I routinely use skip tooth on my 28" Husky.
There are 2 kinds of true rip chain that I know of. The Granville type starts with a set number of cutters, but then grinds off the top plates on every other set of cutters while leaving the side cutters intact. The chain minimizes the load on the saw engine and runs very fast, but is subject to heavy kickback that cannot (I'm told) be controlled by hand. There is also a new rip chain being made by Oregon that uses a very different cutter design.
Maybe our "disagreement" here is the result of different interpretations of the same term. I would just hate to see someone go out and buy true rip chain for their saw when what they really needed was "skip tooth" chain for hand work, and then get seriously hurt. I'd also prefer not to depend on a store clerk to know the difference or give the proper warnings.
Peace.
Mark
-2=mail
one other thing.... *LINK*
TDaniel
>Mark, a chainsaw mill is slicing across the grain, 90 degrees to the heart of the log. We turners sometimes saw in this manner but most of the time when we split a log we do it by sawing with the bar in line with the heart of the log. Doing it this way is much faster but can clog the sprocket guard with the long "chips". The chain that is recommended for a mill is a different chain. I agree with you, most of the local suppliers don't know one from the other. A specialty company like Bailey's or Madsens is where one should go for advice. Ripping a log that is longer than the bar is certainly dangerous, no matter which chain you are using. Kick-back will be fast and hard. On my site you will see a 44" diameter log being split with a 36" bar. I certainly would not advise anyone to do this unless you have many hours of chainsaw operation behind you. You advice is good; ripping long logs with a chainsaw can be dangerous; no matter which chain you use.
TD
http://www.thebowlmaker.com
Re: Oh, Yeah
>Right, a Granville chain is for use with Alaskan type chainsaw mills. That is not what I am talking about. Our ripping chains are skip tooth, sharpened to about 10-15 degrees. They are 3/8" pitch and go on a honking big chainsaw with a 36" bar.
I doubt that a Granville would even fit a regular chainsaw; would it? It seems as if the problem is terminology. :-)
Re: Absa-loootly
>Ain't it great when crossed communications get straightened out and we find we're all on the same side after all?
You and Mark commin' up to Bill's next week?
Mark Mandell
-2=mail
Re: PS
>Just checked and that's "GranBERG" not "GranVILLE" on the noted style of rip chain.
Apologies to Mr/Ms Granberg.
Mark
-2=mail
Bill's
>My sisters, mother and I try to get together once a year and do somehing together. This is aside from the usual family visits. It happens to be the same time as Bill's event.
Re: Bill's
>Our loss.
NEXT YEAR!
