Norfolk Pine Bowls, Pics
Mike Rubes, Apex, NC
>Hi all,
OK, second post of pics for me today. These two bowls were turned from a hunk of Norfolk Pine I got from David Chung in Hawaii. I sent him some eastern hardwoods and he sent me a NP log. If you get a chance to get some and turn it, do it as this stuff is great to turn. These were both turned wet and were a blast. I could get really, really long streamers coming off of these when roughing them out. It was like long pieces of confetti flying off the tool. More fun than a puddle of mud :)
Both of these are end grain turned, sorry I didn't think to get a pic of the bowl looking down on it to show the pith, but you can sort of get that idea from the lit pictures below. One of the bowls has the characteristic "eyes" and the other one doesn't.
Critiques and comments are welcome. After turning to form wet, I soaked them in danish oil for a few days, remounted and wet sanded them with the oil. I then let the oil dry for a few days and buffed them with the Beall. Wet sanding with the oil really ate up the sandpaper in a hurry.
These "light" pictures were taken by me holding the bowl up to a recessed ceiling light. Not the best method, but you get the idea of the translucent nature of Norfolk Pine.
Thanks for taking a look,
Mike
1 day till vacation in Apex, NC!!
Re: Norfolk Pine Bowls, Pics
Nice!
Jennifer@Indy.USA
David Hammond, in Powder Springs GA
>Hey Mike: nice looking bowls! One word of advice that I got from Terry Daniel - sanding with oil should help you, not waste sandpaper. Instead of just soaking the peice, and then sanding with "dry" sandpaper, try soaking the bowl on the lathe while you sand, as well as soaking your sandpaper continualy with oil - if you keep the oil spread liberally on the bowl, and the sandpaper, your sandpaper should last much longer than normal, should cut cooler, and should eliminate that dust cloud you get from sanding dry.
David - transluscence in wood is so cool.
