Onewa Live Center
Onewa Live Center
Onewa Live Center
Fog Tanner
>Has anyone taken a Oneway live center apart and replaced the bearings. There is a little more play than I care for and would like to replace the bearings and eliminate the radial movement. There is a brass ring with two holes in it, which I am assuming is screwed into the body to hold it together. But, I can't tell if it is screwed in, and can't tell if it is left or right hand threads.
I know that Oneway will replace the bearings for $35, but they would be the same bearings I want to take out and I can buy a Vic or Axminster for that. But, since I've got a $100 live center I would like to fix it...so any help is greatly appreicated.
Thanks,
Fog
Re: Onewa Live Center
Bill Grumbine, Kutztown PA
>Hi Fog
I took mine apart a few years ago to regrease the bearings. More accurately, I should say my neighbor the machinist took it apart for me, but he made a spanner which he then gave to me for future operations. If you can find or make a tool that fits into those two holes, a few raps with a mallet is all it takes to get it apart.
Bill
Dave MacLuskie
>If you had to buy again, would you get another Oneway Live Center?
I've considered it, but $100 seems steep. Is it worth it? (Consider I'm new to turning. Having fun but have no intention of making this a profession)
Fog Tanner
>You are right, $100 is a little too much for a center that has loose bearings. If I had it to do again I would buy the Axminster multi point, which is about $60. I have the Vicmarc cup center that came with my lathe, but I like the cone centers for some of the spindle work I do. Both the Axminster and Vicmarc have steel cones where the Oneway is aluminum, I have already bought one new cone and had the other turned where I got too close. You can get either the Vic or the Axminster cone centers for around $35 or less.
But, I do like the threaded end on the Oneway and the ability to make my own ends from wood and screw them on. Also, the large reversable cone is nice - it seems I used it once on something.......
Fog
Fog Tanner
>Thanks Bill, my brother in law is a machinst and has his own shop so I should be able to get a spanner made. Do you happen to remember if the threads or right or left handed???
Fog
Richard Allen
Richard Allen
>Hi Fog
My understanding is that the Oneway live center is designed to have some radial play when it is unloaded. Once the center is loaded the play is eliminated.
I have heard that if the bearing were the type which didn't exibit any play that the live center would cost a LOT more.
Good luck
I like mine
John Crissman
>I really do like my Oneway Live Center. I have not experienced a problem with it at all.
IMHO, the versatility of it and the accessories it comes with is well worth the price. I do use them all.
John
RonZ
>I have the vicmarc heavy duty and then there is also their proffessional model. This is kind of a cup/cone combo. Another viable option is the Robert Sorby deluxe. I have the hollow version and it comes with 7 useful attachments.
Guy
>Hi, I bought mine used from a gentleman a couple years back and I've wondered the same thing. The link for Oneway's answer doesn't seem to really answer the problem. The bottom line is other centers don't exhibit this problem (more or less). Maybe some shims would work. As far as a special tool, check out a bicycle shop. I believe the name of the tool is an "adjustable bottom bracket spanner". Made to adjust the "axle" on a bike. Just bring the live center in and find the one that fits. I have one and I'll try it tonight to see if it works. Take it easy, Guy
Ric Erkes
>I noticed today that Harbor Freight had an adjustable pin wrench in their store. It looked like it would work.
Ric
Barry Turner
>Are you sure it needs "fixing"? I think I heard somewhere that Oneway ball bearing centers were designed to have a little "play".
