Russ Fairfield Question
Mark Kauder
>Russ,
A few weeks ago in response to my questions about poly based grain filler and lacquer compatability issues, you suggested that I use a lacquer based filler made of 4F pummice and lacquer.
I finally got to a Woodcraft yesterday and bought some pummice. Can you give me an idea on the mixing ratios? How thick should it be?
I am posting this now so that I would not forget, but I am heading out of town (and internet contact) until Saturday, so don't think me ungreatful if I do not see your response for a couple of days.
Thanks
Mark
Re: Russ Fairfield Question
>Mark
Years ago I tried pumice, rhotenstone and baking soda. All worked to some degree or the other. I don't remember proportions but mixed them until they formed a thin paste. I remember coloring the baking soda but that was too long ago and don't remember what I used. Sorry I can't remember the up's and downs of each but remember that they all worked.
By the way I've been trying your finishing technique on a mirror. Hope to have it at the symposium. I awlays try something new just to see if it will work for me. This is too time consuming for my general handmirrors but might be useful for my top of the line ones.
>Mark
I forgot to mention that I was using the mix of polyeurethane and boiled linsead oil in those days. That's totally different than lacquer. John
Russ Fairfield
>You can add a little and apply it with a brush, or you can add a lot and apply it with a trowel. My preference is with a brush because the drying and working time is the same as straight Deft. The disadvantage is that it can take more than one coat to fill an open grained wood.
I put the 4F Pumice in a small Mason jar to about 1/3 full, fill it with Deft, and stir to mix.
If I want a heavy filler, I will make a paste with sanding dust and Deft.
>Thanks Russ I'm going to try it since I'm using lacquer now. Between you and Mark I might learn how to use lacquer properly
Mark Kauder
>Thanks John and Russ
Mark
