photographing Glossy vessels
>This is for Mark and others who are interested. Shooting very glossy vessels can be quite difficult. Mostly because they show everything around them.
It started raining so I couldn't spend the time it would take to do it right but Hope you will get the idea. The first shot on the left is the bowling ball sitting in my 3 panel light booth. You can see the panels and the area behind the panels. The bottom of the ball is reflecting the gray which worked fairly well.
For the middle shot I tried to cover all the holes with white cloth including the area between the set and the camera. This will sometimes work for vessels that are light wood color but black or dark vessels just show the all the different panels and cloth. Sometimes if you shoot with a wide open aperture the panels will be out of focus enough to not be very noticeable. In this shot I used a fairly short lens and an aperture about F11 so the panels are pretty noticeable.
The last shot was simply the ball setting on the background with only cloudy skylight, no panels. You can see the sky and the trees around my yard. I used a moderate telephoto (about 180) with an aperture of f4.5. This threw the trees reflected in the ball out of focus. You can see the edges of my background reflected on the left and right. Ideally the background would be larger. This is probably what I would try for Mark's pieces. Change your angle so what you see reflected is the least objectionable.
Shooting this kind of piece in the studio is tough and requires a lot of gadgets and panels.
Re: photographing Glossy vessels
Mark Kauder. Phenix City, AL
>Well John, I may be doomed. Maybe I can just send my bowls to you and pay you in bowls. Look at the pics I am Posting today, they are better (thanks to some of the knowledge transfer from you), but not perfect.
Thanks
Mark
Jorge Casta�eda
>John,
for those pesky all shiny objects, two things may help, the first oneis a polarizing filter, it eliminates reflections some times, if not it lets you rotate them to where are less objectionable.
The second one is using a light table, place your object on top of it, that opens up a whole other way of looking at things.
$0.02
Jorge
>Jorge
I find polarizing filters seldom work on shiney artwork unless you polarize the light source as well. It gets challenging. Also polarizers only work with direct light meaning you can't use things like soft boxes or light panels. Well that's not totally true sometimes they will change things but seldom do what you want.
Light tables sometimes work but usually produce a light glare of their own on the bottom of the vessel. The trick with really glossy vessels is to control everything the vessel "sees". When they are reasonably flat like platters it's not hard. When they are shaped like Mark's they see everything. Your going to get a reflection so the trick is make the reflection as least objectionable as possible.
Hummm...
Jorge Casta�eda
>Maybe shooting inside a black tent...
